Suitcase in elevator - Find pressure on the floor
  • Thread starter Thread starter IAmSparticus
    Elevator Pressure
The discussion revolves around calculating the pressure exerted by a suitcase in an upward-moving elevator. The suitcase has a mass of 16 kg and dimensions of 0.50 m by 0.14 m. The initial calculation for force used the incorrect acceleration value, leading to an erroneous pressure result of 320 Pa. The correct approach involves using the formula for force in a descending lift, which is m*(g-a), to find the accurate pressure. Clarification on the correct method is sought to resolve the calculation error.
IAmSparticus
1.A suitcase (mass m = 16 kg) is resting on the floor of an elevator. The part of the suitcase in contact with the floor measures 0.50 m by 0.14 m. The elevator is moving upward, the magnitude of its acceleration being 1.40 m/s2. What pressure (in excess of atmospheric pressure) is applied to the floor beneath the suitcase?
2. P=F/A
3.
Force=ma = 16kg*9.1.4m/s/s=22.4
A= .5m*.14m= .07
F/A= 22.4/.07
P= 320 Pa
This is wrong, can someone tell me where I went wrong?
Force on the suitcase in a descending lift is m*(g-a).
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
9K
  • · Replies 33 ·
12K
