Summation of the polynomial and division
Susanne217
Let p(z) = \sum_{j=0}^{n} a_{n-j}z^j be a polynomial of at least degree 1 thus
n \geq 1.
Show that if z\neq 0 then 1/z is a root of the polynomial p.
Fundamental theorem of Algebra
If a expand the polynomial above then
p(z) = \sum_{j=0}^{n} a_{n-j}z^j = a_n + a_{n-1}z + a_{n-2}z^2 + \cdots + a_0 z^n
to test if 1/z is a root of p then this must be equal too
p(1/z) = \sum_{j=0}^{n} a_{n-j}z^j = a_n + a_{n-1}(1/z) + a_{n-2}(1/z)^2 + \cdots + a_0 (1/z)^n = 0
Then as I see it its my task to show that the new sum
\sum_{n=0}^{\infty} a_n (\frac{1}{z})^n converges to zero. Then by the ratio-test
\frac{a_{n+1}(\frac{1}{z})^{n+1}}{a_n (\frac{1}{z})^{n}} \rightarrow 0 as z \rightarrow \infty therefore 1/z is a root of p.
Am I on the right track here?
I think your problem should be formulated as follows. If
q(z) = \sum_{j=0}^{n}a_{j}z^{j}
and we define p(z) in the way you have written down, then if q(z)=0 for z not equal to zero, then we have that p(1/z) = 0.
Hi Count Iblis and thank you for your answer,
So what you are saying (please correct if I missunderstand) that if I show that if q(z) doesn't converge to zero then p(1/z) = 0 is a root of p?
thats easy cause if n is of degree at least 1 then then in my understanding
\lim_{n \rightarrow 1} q(z) \rightarrow 1
q(z) is assumed to be zero for some z. And then you can see that
p(1/z) must be zero as well. This, of course, for z itself not equal to zero, otherwise 1/z would not exist.
I don't see how convergence plays any role here, as we're dealing with polynomials...
I see that now :) But is this really that easily? No need to show anything to show that p(1/z) is a root of p?
You do need to show that p(1/z) is zero. You can take the expression for p(1/z) you wrote down:
a_n + a_{n-1} 1/z + ...+a_0 1/z^n
If you multiply this with z^n, you get...?
I get 1, but if I can't use convergense how else am I suppose to show that its zero?
What I mean is:
(a_n + a_{n-1} 1/z + ...+a_0 1/z^n) z^n =
a_n z^n+ a_{n-1} z^(n-1) + ...+a_0
I am such a dumb person Count...
If you multiply the above by z^n then you get the original p(z)...
where q(z) = z^n for a set not equal to zero then p(1/z) = 0 and thus 1/z is a root of p :) Right ?
