Sums of even and odd functions
Charismaztex
If f:(-a,a)-->Real numbers, then f can be rewritten as the sums of an even and an odd function
Let k: Real numbers\{-1}-->Real numbers be given by k(x)=\frac{x^2+4}{x+1}
(i) Prove that there is no interval (-a,a) on which k is either even or odd
(ii) Find an even function g, an odd function h and a value a for which
k(x)= g(x) +h(x), x belongs to (-a,a)
(iii) Explain why it is, or is not, true that k(x)=g(x) +h(x) for all x in the domain of k
N/A
(i) Is it true that by proving k(x) does not equal k(-x) and k(x) does not equal -f(-x), we can prove that there is no interval (-a,a) on which k is either even or odd?
(ii) I am not quite sure here.
(iii) is it not true because x cannot be -1?
Thanks in advance,
Charismaztex
For i) use a proof by contradiction. Assume there is an interval (-a,a) on which k is either even or odd, then on some subset of that, say [-b,b], it must be either even or odd as well.
ii) Study t(x)= f(x) - f(-x)
iii) Give it another look once you find g(x) and h(x). In response to your original attempt, I suggest you read the question again carefully. Whilst it is true that x can not be -1, -1 is not in the domain of k. Good luck
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
