B Understanding Supercritical Fluids: Properties, Risks, & Applications
  • B
  • Thread starter Thread starter RobA
    Fluids
Supercritical fluids (SCFs) exhibit properties of both gases and liquids, making their behavior during vessel failure complex. In the event of a rupture, the outcome depends on how close the SCF is to its critical point; it could behave more like a gas or a liquid. If the SCF is near its critical point, the release could result in a rapid expansion similar to a gas explosion. Conversely, if it is further from the critical point, the release may resemble a liquid's behavior, resulting in a less explosive outcome. Understanding these dynamics is crucial for safety in applications involving SCFs.
RobA
Hi, looking for help understanding the concept of SCF's. I understand that SCF'S are indistinguishable in their gas and liquid phases, and that they show properties of both. My question is, whose properties would they show in the event of a vessel failure?
For example, if you took a 100 l pressure vessel, and filled it with a gas to say, 100 atm (around 1500 psi) and the vessel (for whatever reason) failed, it would be a catastrophic explosion as a very dense cloud of gas would be expanding out at an explosive rate.
At the same time, if you filled that vessel with 100 litres of water (or any liquid) and then pressurized it to 1500 psi, and the vessel failed, you would have a loud noise, the vessel would crack and water would shoot out, but it would not be a catastrophic explosion, since water basically does not compress. There would be no explosive expansion.
So now let's say you've filled the vessel with water and then bring it up to its super critical point. At this point, the liquid is behaving like a liquid AND a gas inside the vessel. Now imagine the vessel ruptures, what happens? Do we get an explosion like with a gas? Or a loud thud like with a liquid?
Thanks in advance
Depends. How far from the critical point are you?
<snip>
Check out these videos:
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
