Understanding the Limitations of Superposition Principle in Electronics
The superposition principle applies primarily to linear and bilateral circuits, but it can still be utilized in certain non-linear scenarios, such as diode circuits, by making specific assumptions about the diode states. Each diode state can be modeled linearly, allowing for the application of superposition to analyze the circuit effectively. When introducing additional sources, the same analysis method can be applied by shorting voltage sources and opening current sources. Understanding the limitations of superposition is crucial, yet it remains a powerful tool in electronics. Mastery of superposition, alongside Ohm's law, is essential for success in the field.
Godwin Kessy
According to superposition principle the circuit involved must be linear and bilateral right?
But how comes the theorem is sometimes used in some of electronics problems example the diode circuits of which are unilateral circuits... Can anyone please explain me clearly the limitations of this theorem...?
Well I haven't seen the examples in question, but one should be able to use superposition for a diode problem, once assumptions about the diode states are made.
For each diode state the diode symbol could correspond to a linear circuit model (perhaps a voltage source, or a voltage source and a resistance in series). For valid sets of diode states, superposition should hold.
I would think superposition would work for any of your circuits with more than one supply.
Follow your V=IR rules, etc...and all should be good.
Regardless of the linearity of your circuit...
Let's say you have a non linear circuit and you find what you are looking for...say the vars consumed by a capacitor.
Now let's say you add another source to the circuit.
Whatever method you used the first time...just use again for the second source.
When the other source is a voltage source...short it...when the other source is a current source...open it.
I've often said that V=IR will get you 50% thru school. Well...superposition will get you through the other 50%...lol.
Superposition is the absolute king of electronics. Embrace it. Love it.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
