Surface area obtained by solid of revolution
lillybeans
Find surface area of solid of revolution obtained by rotating the curve:
y=x2/40-5lnx
from x=5 to x=7, rotated about x=-4
The problem is I know how to do this if I rotated it about x-axis/y-axis, but I have no idea how to do it if the axis is shifted. I did it pretending it was rotated about the y-axis (since x=-4 is parallel to the y-axis), and my answer came out wrong.
I used:
SA=∫2∏x ds, where ds=√(1+[f'(x)]2) dx
So I found the derivative of the function, everything was fine. I squared and square-rooted, found the integral to be:
∏/10 ∫ x^2+100 dx (evaluated from 5 to 7)
but i didn't use the piece of information "axis of rotation is x=-4" anywhere in my solution. I don't really know how to go about using it, please help?
Do I just change the formula from SA=∫2∏x ds to SA=∫2∏(x+4) ds since the axis is shifted to the left 4 units, so the distance to the axis of rotation would be 4 units longer?
Although the answer is still not correct...
or do I change the function so that it goes from y=x^2/40-5lnx to y=(x-4)^2/40-5ln(x-4)? Or none of the above?:/
Deleted.
BluFoot said:
You are correct in that the radius is equal to (x+4).
The volume should be equal to:
∫ from 5 to 7 2π(x+4)(x^2/40-5lnx) dx
Is that what you did?
Thanks for answering, but I don't understand the second part of the integral. Why is it (x^2/40-5lnx) dx?
I thought it should be:
∫2∏(x+4) ds
where ds is
√(1+[f'(x)]^2) dx, and f'(x) is the derivative of x^2/40-5lnx?
Deleted.
OHHH NEVERMIND! I'm stupid, you're looking for surface area, not volume. Ignore everything I've said, sorry!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
