Surface area of a spherical cap by integration
1 reply · 8K views · last reply
Moana
hi guys,
i have a question.
i saw this picture, and i don't really understand how they derived with the formula. The aim is basically to find the formula for the surface area of a spherical cap.
why do you differentiate the x=sqrt(rˆ2-yˆ2)? how does that help to find the surface?
and then next, what role does 'ds' play in here ?
and how do you know that Sy= 2pi (∫cd) x ds?im really confused and appreciate your answers
  • Worked example deriving the surface area of a spherical cap of height h by integrating x ds over y from r-h to r, with a 3D sphere diagram showing the cap above the y-axis, ending in S = 2πrh = π(r² + h²).
Moana said:
hi guys,
i have a question.
It looks like the surface area of the cap is being calculated using the arc length of part of the semi-circle whose altitude is h in the upper hemisphere.
Since the equation of the sphere is x2 + y2 + z2 = r2, where r is the radius of the sphere, a cross section of the sphere in the x-y plane will be a circle having the equation x2 + y2 = r2. The lower edge of the cap is located at y = r - h below the top of this circle on the y-axis. The x location corresponding to this is ##x = \sqrt{r^2-y^2}##. Once you know x and y, you can calculate the length of a small segment of the circumference of this circle, ds. The rest of the calculation is an application of Pappus' Centroid Theorem:
http://mathworld.wolfram.com/PappussCentroidTheorem.html
Here, ds has a centroid which is located at x units from the y-axis, which also serves as the axis of revolution for this calculation.
