Surface formula identification
sapiental
Identify the surface given by the equation 4x^2 +4y^2 −8y −z^2 = 0.
x^2/c^2 + y^2/c^2 - z^2/c^2 = 1
(textbook definition for hyperboloid of one sheet.
I know just by looking at the textbook formula what surface this is. However, my professor gives the following answer for the problem..
It is a hyperboloid of one sheet, x^2 + y^2 − z2/2^2 = 1
I get what the surface is, I just don't understand how he algebraically changed the formula to the above solution..
is (4x^2 +4y^2 −8y −z^2 = 0 ) the same as (x^2 + y^2 − z2/2^2 = 1)?
thanks. :)
complete the square on the y term.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
