Surface Integral of Two Surfaces
The discussion revolves around computing a surface integral over a portion of a cone defined by the cylinder x^2+y^2=2x. The surface S is parametrized using T(u,v) = (vcosu, vsinu, v), and the intersection curve of the cone and cylinder is parametrized as C(t) = (cos t, sin t, 2cos t). To evaluate the integral, the limits of integration for u and v are determined using the conditions from the cylinder, with u ranging from 0 to 2π and v from 0 to 2. The final integral is expressed as ∫∫ f(T(u,v)) ||T_u X T_v|| dA, facilitating the calculation of the surface integral.
Lomion
Hello!
This is a question from one of our past exams, and it's had me stumped for the past hour. The question states:
The cylinder x^2+y^2=2x cuts out a portion of a surface S from the upper nappe of the cone x^2+y^2=z^2.
Compute the surface integral: \int\int (x^4-y^4+y^2z^2-z^2x^2+1) dS
I'm mainly having trouble getting started. What exactly is the surface that we're supposed to evaluate the integral over?
My guess on this question is that I should parametrize the cone:
And use that to find T_u X T_v.
But what do I do after this? In order to find the limits of integration for u and v, do I use the conditions given by the cylinder? v = 2cosu?
Using that still doesn't give me the numerica limits for v, though.
Help, anyone?
To answer your question, yes, you should use the conditions given by the cylinder to get the limits of integration for u and v. The equation x^2+y^2=2x can be rewritten as 2cos^2u + 2sin^2u = 2vcosu. Since v is a function of u, the limits for u can be determined by solving this equation for u. That is, the limits of u will be the domain of the equation 2cos^2u + 2sin^2u = 2vcosu. From there, the limits of v can be determined by substituting the limits of u back into the equation x^2+y^2=2x. Once you have the limits of u and v, you can then parametrize the cone with T(u,v) = (vcosu, vsinu, v), calculate T_u X T_v and use that to evaluate the surface integral.
Hi there!
The surface that we are supposed to evaluate the integral over is the surface S that is cut out by the cylinder x^2+y^2=2x from the upper nappe of the cone x^2+y^2=z^2. In order to evaluate the integral, we first need to find the parametrization of S.
As you have correctly guessed, we can use the parametrization of the cone T(u,v) = (vcosu, vsinu, v) to find the parametrization of S. To do this, we need to find the intersection curve of the cone and the cylinder. This curve can be parametrized as C(t) = (cos t, sin t, 2cos t).
Next, we can use the parametrization of C(t) to find the parametrization of S. This can be done by setting z = 2cos t in the parametrization of the cone T(u,v). This gives us T(u,v) = (vcosu, vsinu, 2cosu).
Now, we can find the surface integral by using the formula:
\int\int f(x,y,z) dS = \int\int f(T(u,v)) ||T_u X T_v|| dA
where T_u X T_v is the cross product of the partial derivatives of T with respect to u and v, and dA is the area element in the u-v plane.
To find the limits of integration for u and v, we can use the conditions given by the cylinder, x^2+y^2=2x. Since we have already parametrized the curve of intersection as C(t) = (cos t, sin t, 2cos t), we can use the limits of t to find the limits for u and v. In this case, t ranges from 0 to 2pi, so u ranges from 0 to 2pi and v ranges from 0 to 2.
I hope this helps! Let me know if you have any further questions. Good luck on your exam!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
