Why do sodium ions not continuously build up in swimming pools?
  • Thread starter Thread starter Nathi ORea
    Chemistry Swimming
Sodium ions do not continuously build up in swimming pools due to several factors. When NaCl is added, it undergoes electrolysis, producing Na+ and OH-. While OH- can accumulate and requires neutralization with HCl, the amount of OH- generated is independent of the Na+ concentration, relying instead on the charge passed through the solution. Additionally, water exchanges, such as splashing or overflow, help maintain salt levels by removing some of the dissolved salt. This balance allows for a steady state where salt levels can remain stable. Increased salinity can enhance buoyancy in the water, providing a potential benefit.
Nathi ORea
TL;DR Summary
Where do sodium ions go in a pool?
It is killing me trying to understand why sodium ions don't continuously build up in swimming pools.
You add NaCl to a pool. It is electrolysed to H2 and Cl2 leaving Na+ and OH-.
I get OH- builds up over time, and needs to be neutralised by HCl to make NaCl again and water. This would balance out charges, but you quite often put more NaCl in the pool.
I would guess the Cl2 leaves as a gas or perhaps as HCl gas over time, but there must be some mechanism for how Na+ leaves. Can someone help me?
Chemistry news on Phys.org
No such mechanism, Na+ will build up.
Likes jim mcnamara
Does this mean that our swimming pools become saltier over time? Does this also mean that we have to add more hydrochloric acid as time goes on too because there is more NaOH to neutralise?
Yes.
No. Amount of OH- produced by electrolysis doesn't depend on amount of Na+ present, only on charge that was passed through the solution.
Likes Nathi ORea
As with any water system, exchanges of water (like splashing water out aand the replacing it with fresh (salt free) water, or overflowing the pool with new water) will reduce the salt levels by actually removing the salt in solution.
A steady state could be achieved if the removal of salt is balanced by the additions of it.
There are several ways to measure the saltiness of water, depending on the range of salinity being measured.
An advantage might of increased salt might be that you will become more buoyant as the salt levels go up.
Likes Nathi ORea
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
