Symmetry about the origin?
In summary, the graph of the relation y=(x-3)^{3} is not symmetric with respect to the y axis, x axis, or the origin. This is confirmed by substituting -x for x and -y for y, which does not yield an equivalent expression. The correct symmetry point is (3, 0), not the origin as stated on the answer sheet.
bacon
69
Determine whether the graph of the relation is symmetric with respect to the y axis, x axis, or the origin.
y=[tex](x-3)^{3}[/tex]
I don't know how to produce a visual of the graph with this post but it is a graph of y=[tex]x^{3}[/tex] moved 3 units to the right along the x axis. Visual examination of the graph tells me that the equation is not symmetrical about the y axis, the x-axis or the origin.
Using the tests for symmetry seem to confirm this.
For y symmetry: substituting -x for x does not yield an equivalent expression.
For x symmetry: substituting -y for y does not yield an equivalent expression.
For symmetry about the origin: substituting -x for x and -y for y also does not yield an equivalent expression. I get y=[tex](x+3)^{3}[/tex]
The answer given on the answer sheet is that the expression is symmetric about the the origin. I am not seeing this.
Thanks for any replies.
y= (x- 3)2 is clearly not symmetric about the orgin. It is symmetric about the point (3, 0). Perhaps that was what was meant- or it is just a typo.
I would suggest taking a closer look at the graph and the equation to determine if there are any errors or discrepancies. It is possible that the answer sheet is incorrect or that there was a mistake in the equation given.
One way to check for symmetry about the origin is to plot points on either side of the origin and see if they are reflected across the origin. For example, if we plug in x=2, we get y=(-1)^3=-1. If we plug in x=-2, we get y=(-5)^3=-125. These points are not symmetric about the origin, as they are not reflected across the origin.
Another way to check is to use the substitution method you mentioned. If we substitute -x for x and -y for y in the original equation, we get y=(-x-3)^3. This is not equivalent to the original equation, so it is not symmetric about the origin.
Therefore, based on these tests, it seems that the graph and equation are not symmetric about the origin. It is important to carefully review and double check all calculations and solutions in scientific work to ensure accuracy.
1. What is symmetry about the origin?
Symmetry about the origin is a type of symmetry in which a figure or object is reflected across the origin, or the point (0,0) on a coordinate plane. This means that the figure is mirrored on both sides of the origin, with each point on one side having a corresponding point on the other side that is the same distance from the origin but in the opposite direction.
2. How can I determine if a figure has symmetry about the origin?
To determine if a figure has symmetry about the origin, you can use a few different methods. One method is to draw a line through the origin and the figure and see if the figure is the same on both sides of the line. Another method is to use the coordinates of the points on the figure and see if there is a point on one side that is the same distance from the origin as a corresponding point on the other side, but in the opposite direction.
3. What are some real-life examples of symmetry about the origin?
Symmetry about the origin can be seen in many natural and man-made objects. Some examples include snowflakes, flowers, and butterfly wings, which have radial symmetry about the center point. It can also be seen in many logos and designs, such as the McDonald's golden arches or the Star of David which both have symmetry about the center point.
4. How is symmetry about the origin different from other types of symmetry?
Symmetry about the origin is different from other types of symmetry, such as reflection or rotational symmetry, because it specifically involves a reflection across the origin. This means that the figure is mirrored exactly on both sides of the origin, while other types of symmetry may involve reflections across different lines or rotations around a point.
5. Why is symmetry about the origin important in mathematics and science?
Symmetry about the origin is important in mathematics and science because it helps us to understand and describe the patterns and structures found in the natural world. It is also a fundamental concept in geometry and can be used to solve problems and make predictions in various fields, such as physics, chemistry, and biology. Additionally, symmetry about the origin plays a crucial role in art and design, as it is often used to create visually appealing and balanced compositions.
