Symmetry Argument for Cylinder
The discussion revolves around understanding the symmetry arguments related to Gauss's Law for an infinitely long cylinder, specifically how the electric field (E) can be simplified in the context of the integral ∫EdA=q/ε. Participants are exploring the implications of cylindrical symmetry and the behavior of the electric field at different points around the cylinder.
  • Participants discuss the nature of cylindrical symmetry and the conditions under which the electric field can be considered constant across the surface. Questions are raised about the treatment of the electric field at the ends of the cylinder and the implications of reflection symmetry in this context.
The conversation is ongoing, with participants providing hints and clarifications regarding the application of reflection symmetry. There is recognition of the need to differentiate between the charged cylinder and the integration surface, with some participants suggesting that the integration surface should be finite with end caps.
There is some confusion regarding the treatment of the electric field at the ends of the cylinder, with participants questioning whether the infinite nature of the cylinder affects the assumptions made in the analysis. The discussion also touches on the divergence theorem and its application in this scenario.
PlatoDescartes
I want to check my understanding of the symmetry arguments that allow for E to come out Gauss's Law and the symmetry arguments that allow for E vector *dA to become EdA. Specifically for an infinitely long cylinder.
∫EdA=q/ε
So, for an infinitely long cylinder, we know that the orientation does not change when translated or rotated about an axis. The E field also is perpendicular to the curved surface of the cylinder, and so there is cylindrical symmetry (obviously). We know that the E field always points in the same direction, so we can essentially 'get rid of' the vector. Next, we assume that the E field is the same magnitude at all points (constant) on the cylinder (there is nothing to suggest otherwise), we can pull it out of the integral, so the integral becomes E∫dA.
But why can the E field at the ends of the cylinder be ignored (which allows us to make all the previous assumptions)? Is it because they are in different directions, so they cancel out?
Hint: Reflection symmetry.
I am sorry but I am a bit confused as to how to apply reflection symmetry as an argument...
∫EdA=q/ε
An infinitely long cylinder does not have ends.
That makes sense; it's just a bit odd to think about! Thank you.
Wait a minute here, the charged cylinder no. But he is talking about applying the divergence theorem to find the electric field. The cylinder you integrate over should be finite and have end caps.The OP is implicitly talking about two cylinders. The source and the integration surface.
What happens to the field if you make a reflection in a plane perpendicular to the cylinder?
I agree that the integration surface is a finite cylinder, and if the OP is wise he/she will take its ends to be perpendicular to the cylindrical axis. That way, the electric field points along the integration surface at the end, and so ##\vec{E} \cdot d\vec{A}## vanishes on the ends.
  • · Replies 36 ·
  • · Replies 19 ·
