Understanding Symmetry Breaking: A Guide to Everyday Examples
In summary: I'll try to explain it in a way that is more comprehensible. Particle physics is all about understanding the behavior of matter and forces at the atomic and subatomic level. And one of the ways we do that is by looking at how particles interact. For example, let's say we have two particles, A and B. A and B are both atoms, and atoms are the smallest particles that make up matter. A and B can interact in two ways: they can collide, or they can exchange waves. Collisions happen when A and B collide with each other. When they collide, they create a lot of energy. And
TimeRip496
254
I don't really understand what this really means.
To understand how a symmetry can be "broken", we descend from the land of abstraction back to everyday world. Imagine you are on a train, zipping through the countryside. E.g. Let's make it a super modern train, using magnetic levitation to float above the tracks. If the train is sufficiently quiet and free of bumps along the ride, there is no way we can tell what speed we're moving at without looking out the window. Just by minding our business, doing physics experiments inside the train, the speed at which we're moving doesn't matter.The remarkable fact is hidden from us in our everyday experience for a simple reason: we can look outside and it becomes clear how fast we're moving, because we can measure/estimate our speed relative to the ground/air. This is an example of symmetry breaking. The laws of physics don't care how fast you are going, but the ground/air do. They pick out a preferred velocity, namely "at rest with respect to the ground." The deep-down rules of the game have a symmetry, but our environment don't respect it; we say that symmetry is broken by the environment. That's exactly what the Higgs field does to the weak interactions. The underlying laws of physics obey a certain symmetry but the Higgs breaks it.
The symmetry breaking we've been talking about thus far is often called "spontaneous" symmetry breaking. That's a way of saying that the symmetry is still there, hiding in the underlying equations that govern the world, but some feature of our environment is picking out a preferred direction. Being able to stick out your hand out of the window of a train and measure your speed w.r.t. air doesn't change the fact that the laws of physics are invariant with respect to different velocities.
From what I read above, symmetry breaking is like the schrodinger's cat experiment whereby the cat is both dead or alive and that opening the box will break the symmetry as it will lead to nature deciding the fate of the cat based on what is stated earlier. (Though i don't really know what the symmetry of the cat in box is and how it relates to my understanding of symmetry as shown below.) So symmetry breaking should be like how nature decides the outcome from all the possible ones.
From my understanding, symmetry is similar to invariance such as speed of light is always the same regardless of speed, thus symmetry is a way of saying "we can alter things in some particular way and nothing important changes." But shouldn't symmetry breaking be like how the speed of light is violated, in that sense what was invariance can be violated under some circumstances.
I don't know maybe it is because i didn't really understand symmetry correctly. Can someone enlighten me? Thanks a lot!
Hi TimeRip:
Have you read the Wikipedia article? You can find it by searching with your brouser on
symmetry breaking !wiki​
Hope this helps.
Regards,
Buzz
Buzz Bloom said:
Hi TimeRip:
Hope this helps.
Regards,
Buzz
Yes I did. And it is not just wikepedia I did went online to search for answers that I can fully understand but most of them involves math which I am not used to. Thats why I need analogy(as shown above) to allow me to better comprehend it.
Hi @TimeRip496:
The problem with an analogy explanation in physics is that it is quite common for many of the aspects of the analogy to lead one astray. It is typical that the writer of an analogy understands its intended limitations, but a reader won't know where these limitations are.
In the Wikipedia article, the example given about a 1834 discovery by Jacobi seems reasonably clear. Is there any part of that description that you don't understand?
Regards,
Buzz
Buzz Bloom said:
Hi @TimeRip496:
Regards,
Buzz
Sorry but I don't really understand it cause I am new to this ellipsoid, hydrostatic equilibrium and bifurcation thing. But then does symmetry by itself means invariance in the first place? And is symmetry breaking the violation of that invariance or not?
Hi TimeRip:
I am also somewhat confused about the concept of symmetry breaking as it applies to particle physics, mostly because the group theory aspects are over my head. The jacobi example I find quite useful, since it shows the concept in a much simpler context. The point of the example is that a physically stable symmetry (the ellipsoidal shape having 3-axis symmetry) is an equilibrium solution to a physical problem, and this changes if a certain relationship no longer holds, in this case
"when the kinetic energy compared to the gravitational energy of the rotating body exceeded a certain critical value."​
In particle physics the nature of the symmetry is abstract, and the relationship condition is about temperature.
Regards,
Buzz
1. What is symmetry breaking?
Symmetry breaking is a phenomenon in which a system or object that appears to have symmetrical properties actually exhibits a preferred direction or state. This can occur due to external influences or internal processes.
2. Can you provide an everyday example of symmetry breaking?
One everyday example of symmetry breaking is the appearance of a snowflake. While the overall shape may appear symmetrical, the intricate details and patterns are actually a result of small variations in temperature and humidity during the formation of the snowflake.
3. How does symmetry breaking relate to physics and mathematics?
Symmetry breaking plays a significant role in both physics and mathematics. In physics, it helps explain the behavior of particles and the formation of structures in the universe. In mathematics, it is used to study patterns and symmetries in equations and geometric shapes.
4. Can symmetry breaking be controlled or manipulated?
While symmetry breaking can occur naturally, it can also be intentionally controlled or manipulated. In materials science, for example, scientists can design materials with specific symmetries to control their properties and functions.
5. Is there any practical application of understanding symmetry breaking?
Understanding symmetry breaking has many practical applications in various fields, such as physics, chemistry, biology, and engineering. It can help us design new materials, improve manufacturing processes, and gain a deeper understanding of the natural world.
  • Other Physics Topics
  • Atomic and Condensed Matter
