Integral Solutions for n,m Positive Integers
yungman
\int ^b_0 cos(\frac{(n-m)\pi}{b}x) dx
\int ^b_0 cos(\frac{(n+m)\pi}{b}x) dx
n and m are positive integers.
\int ^b_0 cos(\frac{(n-m)\pi}{b}x) dx = \frac{b\;sin[(n-m)\pi]}{(n-m)\pi}
Obviously answer is zero if n not equal to m. This is a sync function. I don't know how to derive the answer. From the graph, the answer should be b, but how do I derive it.
Also I want to verify:
\int ^b_0 cos(\frac{(n+m)\pi}{b}x) dx = \frac{sin[(n+m)\pi]}{(n+m)\pi} = \frac{b}{(n+m)\pi}
Thanks
yungman said:
\int ^b_0 cos(\frac{(n-m)\pi}{b}x) dx = \frac{sin[(n-m)\pi]}{(n-m)\pi}
This isn't correct. Almost, but not quite. Surely your integral should be a function of b, no?
Indeed.
yungman said:
This is a sync function. I don't know how to derive the answer. From the graph, the answer should be 1, but how do I derive it.
Why do you think that be answer should be one?
\int ^b_0 cos(\frac{(n+m)\pi}{b}x) dx = \frac{sin[(n+m)\pi]}{(n+m)\pi} = \frac{0}{(n+m)\pi}=0
You won't be able to verify this, because it isn't correct - see the above comments.
Thanks[/QUOTE]
Indeed.
Thanks
[/QUOTE]
I have covered my tracks on my original post. Too bad I cannot change what you quote my answer to cover my track!:bugeye::eek:!LOL!
Yes I was rushing to post late last night and forget the b. How does this look now? Also how do I derive the sync function?
Thanks
Thanks[/QUOTE]
The first one is now correct, the second one isn't - probably just another typo.
In order to compute the value of the integral when n=m, think about what happens in the limit as n-m approaches zero.
Yes, the second answer is wrong all together.
\frac {b \;sin(n+m)\pi}{(n+m)\pi}
where this is a sinc function equal to zero if n and m are integers.
Thanks
Alan
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
