Tan ##2 \theta=4 /(1-1)##. This means ##2 \theta=90^{\circ}## Why?
  • Thread starter Thread starter ElectronicTeaCup
    Means Tan
The discussion revolves around the equation tan(2θ) = 4/(1-1), which leads to an undefined expression since the denominator equals zero. Participants explore the implications of this undefined state, noting that as θ approaches 90 degrees, tan(θ) diverges to positive infinity. The conversation also touches on the ambiguity of the expression 1-1 and its impact on the interpretation of limits in trigonometric contexts. Additionally, the validity of using algebraic manipulations in this scenario is questioned, emphasizing the need for clarity in problem statements. Ultimately, the consensus is that the original problem is not well-defined due to the division by zero.
ElectronicTeaCup
Tan ##2 \theta=4 /(1-1)##. This means ##2 \theta=90^{\circ}## and ##\theta=45^{\circ}##
None
One of my solutions had this in one part. Why is this the case?
For what values of ##\alpha## does ##\tan{\alpha}## diverge to positive infinity?
Likes ElectronicTeaCup
ElectronicTeaCup said:
Homework Statement:: Tan ##2 \theta=4 /(1-1)##. This means ##2 \theta=90^{\circ}## and ##\theta=45^{\circ}##
Relevant Equations:: None
You know that as ##\theta \rightarrow \frac \pi 2## then ##\tan \theta \rightarrow +\infty##?
Likes ElectronicTeaCup and etotheipi
Oh right, I wasn't even thinking about infinity, I was just thinking of it as "undefined"
Also, is this also correct?##\begin{array}{l}
\cot 2 \theta=0 \\
\frac{\cos 2 \theta}{\sin 2 \theta}=0 \\
\cos 2 \theta=0 \\
2 \theta=90
\end{array}##
\cot 2 \theta=0 \\
\cos 2 \theta=0 \\
2 \theta=90
\end{array}##
That's right where ##2\theta## is between ##0## and ##180°##. Another solution could be ##2\theta = 270°##.
Isn't ##1-1## a bit ambiguous, though? Was this a limit like ##x-1##?
A related example... if we parameterise a circle with ##(x,y) = (a\cos{\theta}, a\sin{\theta})## s.t. ##y' = -\frac{\cos{\theta}}{\sin{\theta}}## and wanted to see where the circle is vertical, would you also take issue with identifying ##\sin{\theta} = 0 \implies \theta = 0, \pi##?
1 - 1 = 0, which is not at all ambiguous. However, the fraction ##\frac 4 {1 - 1}## is undefined.
No problem with identifying the vertical part, but ##y'## either goes to infinity or negative infinity depending on how you choose to make ##\theta## go to either of those values (right or left of ##0## or ##\pi##).
The same thing with the ##1/(1-1)## fraction. Whether you have it ##1-x## or ##x-1##, then, however ##x## approaches ##1##, you will get different results (##\pi/2## or ##-\pi/2##).
@Mark44 this is what I was aiming at.
Likes etotheipi
I see your point, and I the interpretation would be clearer from context.
In most cases where I've seen these sorts of steps, it hasn't mattered from which side you approach ##x## (e.g. for my circle example, a gradient of ##\infty## is equivalent to one of ##-\infty## for purposes of determining the vertical tangent).
Likes archaic
A hand-wavy algebraic solution:
$$\tan 2x = \frac{2 \tan x}{1-\tan^2 x} = \frac{4}{0} \rightarrow 0 = 4-4\tan^2 x \rightarrow \tan^2 x = 1$$
And from here the ##\frac{\pi}{4}## falls out "neatly", along with all the other solutions. But be careful, this is "illegal" math. However, you started off with a statement of ##\frac{4}{0}##, I feel okay using hand-wavy tactics here.
Is that really the problem as given to you? I suggest that you had done some work to arrive at that. If so, please post the actual problem.
Likes SammyS and archaic
I seem not to understand this problem, well what i know is that,
##tan 2x## = ##\dfrac {2 tan x}{1-tan ^2 x}## and given that (from OP)##tan 2θ## = ##\dfrac {4}{1-1}## if indeed ##2tan x=4## then ##⇒tan x=2## which clearly contradicts with ##tan^2 x=1##.
With 0 in the denominator the problem is not well defined so there is no point wasting your time trying to understand it, move on.
Likes chwala
