Find k for Tangent Line of f(x) = x^2 - kx
bubbles
Hi, I need help on a math problem that asks me to find k such that the line is tangent to the function, givenf(x) = x^2 - kx and y = 4x - 9.
I don't know how to solve for k. Is "tangent line" the same thing as the equation that is the derivative of the function?
To find a tangent line:
1) Find the derivative of your function. The derivative gives you the slope of the function for any given x.
2) Find a point on the curve: an x0 and its corresponding y0.
3) Use point-slope form to combine the point and slope into a single equation.
In this case, the x0 is arbitrary. You're not trying to find a particular tangent line at a particular x0, you're trying to find the tangent line for any arbitrary x0.
- Warren
No, while the slope of a tangent line at a particular value x for a given function f(x) is the derivative of that function for the particular value x, the derivative of a function f(x) is the expression of the slopes of the tangent lines for all values of x.
How do I find a point of the curve f(x)=x^2-kx where there are 2 variables?
Every point on that curve is of the form (x, f(x)). k cannot be eliminated until the very end of this problem.
- Warren
There aren't. There is only one variable, x (you know that because it says "f(x)"). The k is an unknown constant. What is the derivative of f(x)= x2- kx, remembering that the variable is x? Knowing that x must give the same "y" value for y= x2- kx and y= 4x- 9 gives you one equation for the two unknown numbers x and k. Knowing that the derivative of f(x)= x2- kx at that x is the same as the slope of y= 4x- 9 gives you another. Now you have two equations for the two unknown numbers, x and k.
(There are, by the way, two correct solutions.)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
