Calculating Water in a Tank Over Time
  • Thread starter Thread starter Idea04
    Tank Time Water
To calculate the amount of water in a tank over time, start with the initial volume of water at t=0, the rate of water entering, and the rate of water exiting. The basic equation can be structured as: Water in tank = (Initial volume) + (Rate of water entering × time) - (Rate of water exiting × time). This equation allows for the determination of the water volume at any given time by substituting the appropriate values. By breaking down each term into its respective components, the calculation can be simplified further. This approach provides a clear method for tracking water levels in the tank over time.
Idea04
How would I be able to calculate the amount of water in a tank after a certain amount of time when there would be a certain amount of water entering the tank with more water exiting the tank at the same time?
Set up an equation and... solve it.
- Warren
is there an equation I can use?
Think about what information you have and what you're trying to find out. I presume you know:
At t=0 volume of water in the tank
the rate at which water enters
the rate at which water exits
This really should be enough if you think about the problem.
Try setting up a basic equation using simple statements in English, not variables first. Something like...
Water in tank = (Water previously in tank)+(water coming in)-(water going out)
Now try to figure out an equation for each term.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
