Tapered Roller Bearing - Static Radial Rating
Evaluating the suitability of indirectly mounted Tapered Roller Bearings for specific radial and axial loads requires understanding both static and dynamic load ratings. The dynamic load rating C_90 has been identified, but the calculation for the required static radial rating remains unclear. It's essential to determine if the catalog's static radial rating must exceed the calculated requirement after confirming that the dynamic rating significantly surpasses the necessary value. Resources from bearing manufacturers provide additional guidance on these calculations. Ensuring both load ratings are adequately addressed is crucial for proper bearing selection.
doriei
I'm evaluating whether indirectly mounted Tapered Roller Bearings (http://goo.gl/FpOEri) are suitable to withstand a given radial and axial loads in both static and dynamic application.
I've managed to find the required dynamic load rating C_90 (or C_10) with the help of the book "Mechanical Engineering Design". However, I can't figure out how I calculate the required static radial rating in order to compare with the catalog value. I'm wondering if I have to show that the catalog value for the static radial rating exceeds the required one once I've proven that the catalog dynamic load rating greatly exceeds (by a factor of 9) the required dynamic load rating?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
