Tarzan's River Crossing Dilemma: Can He Swing Across Safely?
  • Thread starter Thread starter mikesown
Tarzan attempts to swing across a river using a 10.0m vine while weighing 85kg and achieving a speed of 8.0 m/s at the lowest point of his swing. The centripetal force calculated is 544N, which is insufficient to determine if the vine will break. The total force on the vine includes both the centripetal force and Tarzan's weight, which is 833N (85kg x 9.8m/s²), resulting in a total tension of 1377N. Since this exceeds the vine's breaking strength of 1000N, the vine will break, and Tarzan will not make it safely across the river. The calculations confirm that Tarzan's swing is unsafe.
mikesown
"Tarzan" problem
"Tarzan (m=85kg) tries to cross a river by swinging from a 10.0m long vine. His speed at the bottom of the swing, just as he clears the water, is 8.0 m/s. Tarzan doesn't know that the vine has a breaking strength of 1.0 x 10^3 N Does he make it safely across the river? Justify your answer."
F_{c}=\frac{mv_{t}^2}{r}
I attempted to substitute in the variables as such:
F_{c}=\frac{85kg*\left(8.0\frac{m}{s}\right)^2}{10.0m}
I got 544N, which is not the answer(1.37x10^3N is his 'weight' at this point, greater than the rope). Am I missing something obvious?
You do not have the right formula. You are thinking of Centripetal Force, this is Pendulum Motion.
You have correctly identified the centripetal force as 544N. The centripetal force is the net force acting up toward the center of the circle. The net force is a combination of the tension force up and his weight (not his 'weight' as you have described...his weight is m*g) down. Solve for T. Does the rope break?
This is correct. Add 544N to (85 x 9.8) and you get 1377N
Is it too late to pretend I haven't said anything? eep my bad, just ignore anything i say
