Teaching Myself Linear Algebra
In summary: So, even if you don't know what they are yet, you will eventually!What are matrixes? A matrix is simply a collection of numbers in a particular order, with each number representing a "column" in the matrix. So, a 4x4 matrix would have the four numbers in the first row, the four numbers in the second row, and so on.So, solving systems of linear equations is a very common thing to do in mathematics and physics, and understanding vector spaces and matrixes is a prerequisite for doing it.
Saladsamurai
3,020
So I just bought his ook called "Matrices and Linear Algebra" by Hans Schneider and G.P. Barker in an attempt to teach myself this subject as I will probably need to learn it at some point anyway. I am not very familiar with the topic (in any sense) and I was wondering what if any topics up through Calculus 1 I should review (if any of these would even help).
Any thoughts are appreciated. For now I'll just wiki the subject and try to get a general feel of what it even entails...I don't even know what the term Linear Algebra means beyond a linear equation (of the most basic form).
Casey
You don't really need any calculus to learn linear algebra-- unless you want to go through applications.
Like, diagonalization can be used to solve a system of linear, homogeneous ODEs-- so, if anything, the most you need is basic knowledge of separation of variables. (i.e. [tex]\frac{dy}{dt}=ky[/tex])
However, from skimming through the book, it looks like it covers the background you need for the application I mentioned-- so I guess basic knowledge of integration would do.
I see. I am not familiar with ant of those terms, nor does the expression [tex]\frac{dy}{dt}=ky[/tex] have any meaning to me; hopefully I will be able to get that out of the reading. :uhh:
Casey
Don't worry about it-- neither was I. ;)
If you're not familiar with that differential equation, you might need to learn a bit of calculus while studying linear algebra-- but like I said, you don't need it to understand the material, it's mainly a convenience should you ever feel like applying all of the underlying material.
As for what the terms mean, again, don't worry about it... it'll become clearer as you go along.
I've always found linear algebra a little dry and unexciting, but certainly extremely useful in many areas of mathematics. If you stick with it, you might want to check out Abstract Algebra at some point, group theory is generally quite enjoyable to most maths geeks because it starts off so simple and yet has such far reaching consequences :smile:
I don't know the American education system, but once you can, you should enjoy showing that the differential operator is a linear operator.
The main problem I have with learning a new topic is all of the new definitions.
For example, I am still not sure what Linear Algebra even is! I looked it up on Wiki and it seems that in the definition alone there are new terms at every turn. This led to a chain of look-ups and at the end of it all, I was more confused than I was to start!:cry:
Anyone have a good "lay" definition of Linear Algebra for me?:blushing:
~Casey
In a nutshell, it's solving systems of equations (usually in real numbers or matrices), and the special tools used toward that end.
Nice CRGreathouse. That actually helps a lot.
~Casey
Many problems in linear algebra lead to solving a system of linear equations, although this very "problem" is almost trivial from a pure theoretical standpoint.
I am not sure that I quite follow you radou? Though I am sure it is due to my being new to the topic.
What radou is saying is that the description you were given, of solving systems of linear equations, is not a very good one. That is an elementary topic taught in school. Linear algebra is the study of vector spaces and the maps between vector spaces. That is 'all' it is, in the sense of 'the' definition. If you know what a vector space is and a matrix, then you know the basics.
Solving linear equations is finding, if it exists, a point in the intersection of subspaces. It is merely algorithmic, tedious, and dull.
What are vector spaces? Well, let's not get into definitions, but let's content ourselves with saying that an understanding of them is a prerequisite for most any mathematics and physics - we use them as objects of interest in their own right, or use them in modelling physical situations.
it may not be much use , but there is a short (15 page) free linear algebra book on my webpage. a better one is the free one by ruslan sharipov.linear algebra and linear geometry are useful because they are easy, and yet can be used to give approximate answers to non linear and hence hard, problems.
differential calculus is the art of approximating non linear problems by linear ones. hence one does not need calculus to learn linear algebra, but one does need it to apply linear algebra most deeply, e.g. to differential equations.
Thank you Matt Grime and Mathwonk. I will check out that book(s) when I get out of work.
I literally just picked up a book a couple of days ago, so I have not come to the part where I discover that Linear Algebra isn't really about solving equations (at least in the way I thought).
Vector spaces and subspaces have no meaning to me...yet:uhh:
I mean, I know what vectors are from physics 1, but that is the extent of it.
But, be sure that I look foward to learning this. I am going to look up those terms now. (Then I will probably have to search around PF for a translation!:/ )
Casey
the idea is to understand "linearity". i.e. operations that preserve addition and scalar multiplication, like differentiation does.
these are called linear operators, and the spaces they act on are called vector spaces.
so the space of infinitely differentiable functions on an interval is a vector space, and differentiation is a linear operator on it. that's basically what we want to understand.
My geocoities.com/r-sharipov site is now off. Use the following sites instead:
http://ruslan-sharipov.ucoz.com"
http://freetextbooks.narod.ru"
1. What is Linear Algebra?
Linear Algebra is a branch of mathematics that deals with the study of linear equations, vectors, vector spaces, and matrices. It involves understanding and manipulating these mathematical objects to solve problems related to systems of linear equations, transformations, and data analysis.
2. Why is it important to learn Linear Algebra?
Linear Algebra has a wide range of applications in various fields such as engineering, physics, computer science, economics, and statistics. It provides a powerful toolset for solving complex mathematical problems and analyzing data. It also forms the foundation for many advanced topics in mathematics and other disciplines.
3. How can I teach myself Linear Algebra?
There are many resources available for self-learning Linear Algebra, such as textbooks, online courses, and video tutorials. It is important to have a good understanding of basic algebra and geometry before diving into Linear Algebra. It is also helpful to practice solving problems and working through examples to solidify your understanding.
4. What are some common challenges when learning Linear Algebra?
Some common challenges when learning Linear Algebra include understanding the abstract concepts, such as vector spaces and linear transformations, and applying them to real-world problems. Another challenge is keeping up with the notation and terminology, which can be overwhelming for beginners. It is important to take your time and practice regularly to overcome these challenges.
5. How can I apply Linear Algebra in my daily life?
Linear Algebra has many practical applications in our daily lives, such as image and signal processing, data compression, and machine learning. It can also help in making decisions based on data, such as analyzing trends and patterns, and solving optimization problems. Learning Linear Algebra can also improve problem-solving skills and critical thinking abilities, which are valuable in any profession.
  • Science and Math Textbooks
  • STEM Educators and Teaching
  • Linear and Abstract Algebra
  • STEM Academic Advising
