How Can I Teach Myself Chemistry After 20 Years Away from Textbooks?
  • Thread starter Thread starter Lockie123
    Chemistry Teaching
After two decades as a locksmith, an individual plans to pursue a college degree, including two chemistry courses covering various complex topics such as intermolecular forces, atomic structure, and chemical synthesis. The challenge lies in the significant gap since last engaging with academic material, particularly in chemistry and mathematics. To prepare, it is suggested to start with high school-level chemistry and algebra textbooks to build foundational knowledge. Resources like Khan Academy are recommended for supplementary learning through videos. This approach aims to bridge the knowledge gap and facilitate a smoother transition into rigorous college-level chemistry.
Lockie123
After 20 years of being a locksmith, I have decided that I want to get a college degree and I'll be starting next year! As part of my degree, I will be doing two chemistry courses which will cover:
- Intermolecular forces, chemical equilibrium, energy considerations and chemical reactivity applied to aspects of chemistry and biochemistry
- Structure of the atom and molecular bonding
- Chemistry of the metals and non-metals
- Bonding in transition (d-block elements, coordination complexes, bioinorganic systems)
- Aspects of acid/base equilibria, kinetics and electrochemical processes
- Importance of molecular shape and how chemists determine the structure of compounds using spectroscopic techniques including ultraviolet, infrared and nuclear magnetic resonance spectroscopy
- Chemical synthesis with reference to addition and subtraction reactions
- Strategies for synthesis and properties of biologically significant molecules
The problem? It has been two decades since I've touched any textbook, let alone a chemistry textbook, yet I need to learn chemistry from 'what is chemistry?' to first year college chemistry that is rigorous and has a lot of math in it.
If you were in my situation, what would your strategy be? Should I be able to start from a university chemistry textbook?
Do you know enough math to at least do some basic mathematics, such as some simple algebra? After 20 years, there is a good chance you don't have that under your belt. I would pick up a math book for the freshman high school level and do some reading to get acquainted with doing some algebraic manipulations, and once you feel comfortable with that, start off with a first year high school chemistry book.
Something like this would be suitable basic chemistry, which would be on the level of high school chemistry
https://www.amazon.com/dp/0538736372/?tag=pfamazon01-20
And if you need to brush up on algebra I, take a look at this
https://www.amazon.com/dp/0470559640/?tag=pfamazon01-20
These are both quite cheap, just a few dollars. No need to spend a lot of money. Also, look at khanacademy.org to watch videos that give good explanations for math and science, from basic arithmetic all the way beyond calculus. This should keep you busy for a while and get you ready for school.
Cheers @Maylis!
The book is fascinating. If your education includes a typical math degree curriculum, with Lebesgue integration, functional analysis, etc, it teaches QFT with only a passing acquaintance of ordinary QM you would get at HS. However, I would read Lenny Susskind's book on QM first. Purchased a copy straight away, but it will not arrive until the end of December; however, Scribd has a PDF I am now studying. The first part introduces distribution theory (and other related concepts), which...
I've gone through the Standard turbulence textbooks such as Pope's Turbulent Flows and Wilcox' Turbulent modelling for CFD which mostly Covers RANS and the closure models. I want to jump more into DNS but most of the work i've been able to come across is too "practical" and not much explanation of the theory behind it. I wonder if there is a book that takes a theoretical approach to Turbulence starting from the full Navier Stokes Equations and developing from there, instead of jumping from...
