Temperature Change and heat loss
In summary, the object falls from a height of 1.00x10^2m and at a constant speed, causing the water in a well-insulated tank to heat up by 4.69 degrees Celsius.
William Bush
29
1. The problem statement:
A 5.00 x 10^2 kg object is attached by a rope through a pulley to a paddle-wheel shaft that is placed in a well-insulated tank holding 25.0 kg of water. The object is allowed to fall, causing the paddle wheel to rotate, churining the water. If the object falls a verticle distance of 1.00 x 10^2 m at constant speed, what is the temperature change of the water? (specific heat = 4186 J/kg and gravity = 9.81 m/s^2).
2. Homework Equations :
Heat Lost = Heat Gained
Mm Cm (Ti-Tf) = Mw Cw (Tf-Ti)
3. The Attempt at a Solution
The instructor has not lectured on this type of problem but has asked us to read the text and give it a shot. I can't seem to find a way forward with this problem. Is this a calorimetry problem? If so, I don't understand why the distance the object fell and the fact that it fell at a constant speed is important. Any help will be appreciated...thanks in advance!
Hint: Does the energy of the falling object change?
Mechanical work and heat are two different forms of energy. So, think what "conservation of energy" means in this situation.
Re the "constant speed", since the mass is not acclerating you know the tension on the rope is equal to the weight mg, so you can calculate the work done by the rope on the paddle wheel. If the mass was acclerating the tension in the rope would be different.
Conservation of energy say that energy remains constant, although it may change forms; so I would say that at the top, the object had "potential energy" and at the bottom it had "kinetic energy". If my calculations are correct, the object has 490,500J of potential energy. Does this mean that the object introduces 490,500J of heat energy to the water? If so, wouldn't I have to know what the initial temp of the water to determine how much it would change?
I believe that I can determine the work done by the rope on the paddle with the following equation:
W=FdCos0
So, the work done is:
500(100)Cos 90 degress = 50,000
I'm not sure how this applies to my problem though??
Does the object's KE change as it falls?
I didn't check your calculations, but that's the idea: The object transfers mechanical energy as it falls to the paddle, which in turn transforms that energy into "heat". (Note that AlephZero's advice is equivalent--understand what's he's saying.)
No. To find the final temperature you'd need to know the initial temperature--but all you are asked to find is the change in temperature.
W=FdCos0
With what force does the rope pull on the paddle? Reread AlephZero's post.
I see that I made an error calculating the work done by the rope...I forget to multiply the mass by the gravity. After recalculating, I see that the work done by the rope is 490,500. I suppose that it is no coincidence that this is the same as the value I got for potential energy. So If the object introduces 490,500 jules of energy to the water, I now have to figure out how this much energy effects that temp of water...any clues!
specific heat
Here's a clue: http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/spht.html"
Doc Al...you are the man! With your help, I was able to solve the problem. I used the following formula: Q=cm(delta T)
Of course I had to rearrange it to solve for "T" but when I did, I determined that the temperature change was 4.69 degress. I've got more problems to solve but thanks a lot for helping me with this one!
What is temperature change?
Temperature change refers to the increase or decrease in the average temperature of a system, such as the Earth's atmosphere, over a period of time. It is often measured in degrees Celsius (°C) or Fahrenheit (°F).
How does temperature change affect heat loss?
Temperature change and heat loss are directly related. As the temperature of a system increases, the rate of heat loss also increases. This is because objects with higher temperatures have more energy and therefore transfer heat to objects with lower temperatures at a faster rate.
What factors contribute to temperature change and heat loss?
There are many factors that can contribute to temperature change and heat loss, including the amount of sunlight, atmospheric conditions, and the composition of the Earth's surface. Human activities, such as burning fossil fuels and deforestation, also play a significant role in temperature change and heat loss.
How do scientists measure temperature change and heat loss?
Scientists use various instruments to measure temperature change and heat loss, such as thermometers, satellites, and weather stations. They also collect data on factors that can influence temperature change, such as greenhouse gas emissions and land use changes.
What are the potential consequences of temperature change and heat loss?
Temperature change and heat loss can have significant impacts on the environment and human society. These include more frequent and severe natural disasters, changes in weather patterns, sea level rise, and impacts on agriculture and food security. It is important for scientists to study and understand these consequences in order to inform mitigation and adaptation strategies.
