Temperature combination, Homework (HELP)
The discussion revolves around calculating the final temperature of a mixture of ice and water using the principle of conservation of energy. It involves four ice cubes at 0 degrees Celsius and 115 grams of water at 75 degrees Celsius in an insulated container, with no heat loss to the surroundings. The key equations include heat transfer calculations, specifically using q=m x Cs x ΔT and considering the heat of fusion for the ice. The participant acknowledges a misunderstanding regarding the final temperature, realizing it will be lower than 75 degrees Celsius due to the melting of ice. Suggestions are made to write equations that accurately represent the energy balance in the system.
coffeecat91
Four ice cubes at exactly O degrees C having a total mass of 53.5g are combined with 115 g of water at 75 degrees C in an insulated container. If no heat is lost to the surroundings, what will be the final temperature of the mixture?
q=m x Cs x ^T
q= n x ^H fus
Cs ice= 2.09 J/gC
for H20 ^H fus= 6.02 KJ/mol
18.02 g=1 mol for H20
Use the idea of conservation of energy. The heat energy transferred to the ice blocks will be equal to the heat energy lost by the water.
What about the Heat of fusion for the ice melting?
I figured it had something to do with finding the energy to melt the ice (the phase change part) plus the energy as the ice goes up to 75 degrees, and then set the combination equal to the mass of the solution x the specific heat of water x the final temp (unknown) - initial temp 75.
I know that's wrong because the ice doesn't necessarily go to 75 degrees, in fact the temp should be lower. Any suggestions?
Thanks!
Try to write equations describing energy balance as danago proposed. Some of your concepts are OK, once you will write it all as an equation it should be obvious.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
