Temperature distribution - PDE's
Anabelle37
Consider a square of unit length which is insulated on the sides x=0, x=1 and y=0 and has the temperature distribution u(x,1)=x along the side y=1. find the temperature distribution u in the square.
So I have the boundary conditions:
du(0,y)/dx = 0; du(1,y)/dx = 0; du(x,0)/dx = 0; u(x,1)=x (where these are partial derivatives)
I am unsure where to go from here...do i solve laplaces equation? if so I don't know how to put the boundary conditions in terms of the separation of variables method.
please help!
Yes, the equilibrium distribution of temperature on a plate satisfies \nabla^2 u(x, y)= 0.
If you write u(x, y)= X(x)Y(y), then
\frac{\partial u}{\partial x}= Y(y)\frac{dX}{dx}
so
\frac{\partial u(0, y)}{\partial x}= Y(y)\frac{dX(0)}{dx}= 0
so either Y(y)= 0 for all y, which gives only the trivial solution, u= 0 for all x and y or
\frac{dX(0)}{dx}= 0
That's your boundary condition on X.
Similarly for the other two.
ok thanks,
do i partial du/dx for the other 2? or du/dy?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
