Alex.malh
- 17
Hello all,
I'm stuck with following problem:
At our plant we have a tank filled with a liquid maintained on 80°C with a steam coil.
During the night the steam is switched off and the liquid temperature start to drop.
Tank mass not taken into account atm.
mass liquid: 20000 kg
cp liquid: 1.76kJ/(kg °C)
tank surface sides As: 82m²
tank surface top At: 7m²
Heat transfer coeff sides Us: 0.6W/(m² °C)
Heat transfer coeff top Ut: 0.8W/(m² °C)
Tstart: 80°C
Tair: 10°C
Cooling time t: 8h
I used following formulas:
Q=U x A x dT [kJ/s]
E=m x cp [kJ/°C]
Temperature drop = Q/E x t x 3600
Now the heat transfer rate Q is dependable of the dT but that changes in function of time.
The used method is simplified in that aspect and only uses the max heat transfer rate possible in given process.
in other words: this method is linear while reality is not. probably logarithmic i guess.
How can i calculate the temperature drop more accurately?
I'm thinking in direction of thermal equilibrium, get a expression of temperature in function of time of the process.
Thx.
Alex
Tstart: 80°C
Tair: 10°C
Cooling time t: 8h
Q=U x A x dT [kJ/s]
E=m x cp [kJ/°C]
Thx.
Alex
