Temperature due to resistance calculator?
The discussion focuses on creating a calculator to determine temperature from ohm readings, specifically using a thermistor. The original poster is struggling with the coefficients needed for the Callendar-Van Dusen or Steinhart-Hart equations and is advised to take measurements at known temperatures, such as the boiling and freezing points of water, to fit the equations accurately. It is suggested to use a spreadsheet program for curve fitting the provided resistance and temperature data. The importance of gathering additional measurements, particularly at the extremes of the desired temperature range, is emphasized. Overall, accurate temperature calculations depend on proper data collection and fitting methods.
ISX
Think this question is more of a physics than math question. Anyways I am trying to figure out how to make a calculator to figure out what temperature something is at based on the ohm reading I get. I have several readings to go by but I think doing it exponentially is the wrong way to go about it since the readings I calculate are not very accurate based on the quadratic regression method I have been doing.
Wikipedia shows the formula on this page (http://en.wikipedia.org/wiki/Callendar-Van_Dusen_equation) but I don't know how to figure out any of the coefficients or anything.
Thanks for any help I can get!
By:
ISX said:
... I am trying to figure out how to make a calculator to figure out what temperature something is at based on the ohm reading I get...
Do you mean using a thermistor, or just by plugging into any random piece of electronics?
The answer depends sensitively on your situation.
Yeah just a little thermistor.
Guess it would be this equation then. http://en.wikipedia.org/wiki/Steinhart–Hart_equation
Temperature range of interest would be -40 to 212F. I just need help on the coefficient stuff.
Unfortunately I think your best (if not only) bet is to measure some values at known temperatures and fit those to the equation. You have 3 constants, so you need at least 3 measurements, more would be better. The boiling and freezing points of water would be the easiest to do. If you don't have/want-to-use a thermometer, you could use the temperature of boiling and freezing of both pure and salt water for 4 total points.
I do have many measurements. Here are a few. kOhms is first number Temp (F) is the second.
73.00 5.0
65.00 6.6
56.00 13.0
39.00 28.0
25.80 43.0
24.57 46.2
18.96 53.7
I think you should use a thermistor because the temperature varies greatly with the heat-dissipation of the resistors.
It is a thermistor..
Hi ISX
Do you have Excel or some other spreadsheet program? Just put the numbers you have for temperature and resistance and have the program do the curve fit to a polynomial for you.
For the values you provided, the chart is rather limited and I wouldn't suggest using it for values outside the tested limits, but attached is what you'd get. I'd suggest getting some more measurements, especially at the limits of your intended range (ie: test in boiling water, 212 F, and at -40 F).
Another alternative is to get an equation from the thermistor manufacturer.
