Temperature increase by light absorption
The discussion centers on calculating the temperature rise in a crystal that absorbs light and releases excess energy as heat. Key factors influencing this calculation include the power of the radiated light, the reflection coefficient, and the heat capacity of the crystal. For a black body, the relationship between energy and temperature change can be expressed as ΔT = W*t/C. In a general case, the absorbed energy can be calculated using the formula Eabsorbed = (1-ρ)∫W(t)*dt, leading to ΔT = (1-ρ)/C * ∫W(t)*dt. Understanding these variables is crucial for accurate temperature rise predictions.
sciphys1
Hi,
I have a question. If a crystal absorbs light and the absorption process leads to some excess energy being released as heat . Can one calculate the temperature rise or an experiment would most certainly need to be done? Apart from the heat capacity of the crystal before light absorption ,what else would one need to know? Any discussion on this would be highly appreciated.
Thanks.
Sciphys1
Science news on Phys.org
It will depend upon the power of radiated light, reflection coefficient and heat capacity, if you consider the case of a black body, then the radiated energy is W*t, ΔT = W*t/C, if you want a general case, then the absorbed energy Eabsorbed = (1-ρ)∫W(t)*dt, ρ is the reflection coefficient ΔT = (1-ρ)/C * ∫W(t)*dt
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
