Will Two Thermometers in Water at 50 Celsius Have the Same Temperature?
  • Thread starter Thread starter Science Proff
    celsius Temperature
If two thermometers, one filled with mercury and the other with alcohol, are placed in water at 50 degrees Celsius and allowed to reach thermal equilibrium, both will ultimately display the same temperature. Although the specific heat capacities of mercury and alcohol differ, once equilibrium is achieved, they will reflect the same temperature due to the definition of thermal equilibrium. The time taken to reach this equilibrium may vary between the two thermometers, but the final temperature will be identical. The heat transferred to each thermometer does not need to be equal for this to occur. Therefore, despite differences in heat capacity, the thermometers will show the same reading once stable.
Science Proff
I was wondering; if a water is say at a temperature of 50 Celsius and we put two thermometers into it, one which is a mercury in glass and the other which is of alcohol (same mass of both constituents); when we break the thermometers directly after the readings are stabled and we measure what the temperature of the mercury and the alcohol is; is it the same? (If there is no heat loss or unreliability) I am not sure because heat is given by Q=mct and since Q is constant as said no heat loss as it is transferred into the thermometers and mass of both alcohol and mercury is same; but the specific heat capacity of the two are different so I think that the t will also differ even though kept in the same 50 degrees water (i.e. same heat energy). But is it correct? Just confirming.
Science news on Phys.org
If they both reached equilibrium with the water, they will have the same temperature.
It may take different times to reach the equilibrium but once at thermal equilibrium, they must have the same temperature (by definition).
The heat transferred to each thermometer does not have to be the same.
