Temperature of Compressed Air
In summary, compressing air leads to an increase in both pressure and temperature, and the relationship between them can be calculated using the Ideal Gas Equation PV = nRT. However, this relationship can vary depending on the type of process chosen (isobaric, isothermal, isentropic, polytropic, or isochoric) and the values of the fundamental parameters such as pressure, temperature, volume, or entropy. For an adiabatic process, where Q = 0, the first law of thermodynamics states that the change in thermal energy is equal to the work done, resulting in an increase in temperature when compressing air. The equation for this process is Pf = Pi(Vmax/Vmin)^gamma, where gamma
matthewgill
Hello,
We all know that if you compress air the pressure and temperature increase together.
But how can I calculate the relationship?
For example: What pressure (psi) do I need to compress air to so it is 100degC?
Many Thanks,
Matthew.
Science news on Phys.org
The equation is PV = nRT
P = pressure
V = volume
T = temperature
n = the amount of gas, if you don't ad or remove any you can ignore this.
R = a constant to get all this in the correct units.
So basicaly PV/T is the same before and after and as long as you use the same units it all works.
Remember to do this in terms of changes in temperature. If you want this in absolute temperature you need to convert to Kelvin (google absolute temperature)
In Thermodynamics there are different fundamental THERMODYNAMIC PROCESSES namely Isobaric, Isthermal, Isentropic, and Polytropic and Isochoirc processes.
Each of these processes has its own unique method of heating or cooling of the air/gas depending on the boundary conditions or type of surrounding or keeping some fundamenrtal parameters like pressure, tempreature, volume or entropy a constant.
Depending on the typr of process chosen the values and relations between the pressure, tempreature ( as menioned in your case) will vary.
The basic equation is the Ideal Gas Equation PV = mRT which remains applicable in all cases in any process.
But there are another set of equations derived from the above ie PV^n = C, where n is called the polytropic index, and all the above processes have a particular value of n. And depending on this value of n for each process the amopunt of heat or pressure required to heat up or compress air to a particular value will depend on or vary.
It all depends on your choice of process and the variables will change according to the particular equation.
P = pressure
V = volume
T = temperature
OK, this is true for isothermal condition. For an adiabatic system, the temperature increases when you compress air. I should think there is a relation between the temp rise and pressure ratio (before and after compressing)
pixel01 - you have the right idea.
i have found this, which is what I am trying to do. I just need to know the psi required for 100degC rather than 1000degC. Can anyone help change the equation?
QUESTION
What compression ratio Vmax / Vmin will raise the air temperature from 20C to 1000C in an adiabatic process?
the gas is diatomic
ANSWER
For an adiabatic process, with Q = 0, the first law of thermodynamics is:
Change in thermal energy = Work. Compressing a gas adiabatically (W > 0) increases the thermal energy. So an adiabatic compression raises the temperature of a gas.
Pf = Pi(Vi/Vf)^gamma
gamma = 1.40 for a diatomic gas (like air)
Pf = Pi(Vmax/Vmin)^1.40
Wait a minute:
(Tf) Vf^(gamma - 1) = (Ti) Vi^(gamma - 1)
(1,273K)Vf^(gamma-1) = (293K)Vi^(gamma -1)
(1,273K) Vf^0.4 = (293K) Vi^0.4
1,273K / 293K = Vmax^0.4/Vmin^0.4
4.3447 = (Vmax^0.4 / Vmin^0.4)
(4.3447)^2.5 = (Vmin^0.4 / Vmax^0.4)^2.5
Vmax/Vmin = 39.346
So you would need to increase pressure to 2,513 psi if you started from atmospheric pressure.
1. What is the relationship between temperature and pressure in compressed air?
The temperature of compressed air increases as the pressure increases, and decreases as the pressure decreases. This relationship is known as Charles's Law, which states that the volume of a gas is directly proportional to its temperature at a constant pressure.
2. How does temperature affect the performance of compressed air systems?
High temperatures in compressed air systems can cause reduced efficiency, increased energy consumption, and potential damage to equipment. It is important to keep the temperature of compressed air within a specific range to ensure optimal performance and prevent system failures.
3. Can compressed air be used for cooling purposes?
Yes, compressed air can be used for cooling by expanding the air through a nozzle or venturi. The expansion causes a decrease in temperature, allowing the compressed air to absorb heat from its surroundings and provide a cooling effect.
4. How is the temperature of compressed air measured?
The temperature of compressed air can be measured using a thermometer or a temperature sensor. These can be inserted into the compressed air stream or attached to the outside of the system to measure the temperature of the air as it passes through.
5. What factors can affect the temperature of compressed air?
There are several factors that can affect the temperature of compressed air, including the initial temperature of the air before compression, the type and efficiency of the compressor, the ambient temperature, and the rate of compression. Humidity and the presence of moisture can also impact the temperature of compressed air.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
