Temperature Question (answ=neg#-?)
  • Thread starter Thread starter grantP
    Temperature
A .03kg piece of iron loses energy when heated to 100 degrees Celsius and then dropped into cool water, cooling down to 30 degrees Celsius. The calculation shows a change in energy of -945J, indicating energy loss. The negative sign signifies the direction of energy transfer, meaning the iron lost 945J to the water. The final answer should be presented as 945J to reflect the total energy lost. This understanding clarifies the interpretation of negative values in energy calculations.
grantP
[SOLVED] Temperature Question (answ=neg#-?)
A .03kg piece of iron is heated to 100 degrees celsius and then dropped into cool water where the iron's temperature drops to 30 degrees celsuis. How many joules does it lose to the water?(Specific Heat Capacity of Iron=450J)
change-in-energy=(SHC)(m)(Tf-Ti)
change-in-energy=(450)(.03)(30-100)
=-945J
does it matter that my answer is a negative number?
You found the change in energy, which is the final energy-the initial energy
the fact that it's negative implies what? Does that seem correct?
Reread the phrasing of the question. (If the change in the amount of money in your wallet after playing poker is -$5, how much did you lose?)
ok so i think my answer should just simply be 945J instead of -945J because the negative implies that is what i lost, and evidently is exactly what was asked in the question!
is this thinking right?
Correct
