Temperature rise after collision
The discussion focuses on calculating the fractional decrease in total kinetic energy of two colliding asteroids and the resulting temperature rise. The initial velocities and masses of the asteroids are provided, with one moving in the opposite direction. The participant attempts to determine the final velocity after the collision and questions the loss of kinetic energy, suggesting that no energy is lost due to the absence of external forces. However, it is clarified that in an inelastic collision, some kinetic energy is converted to other forms of energy, necessitating a calculation of kinetic energy before and after the collision. The conversation highlights the importance of understanding energy transformation during collisions.
savaphysics
Determine the fractional decrease in total kinetic energy of each set of asteroids when they collide. If the average specific heat of the material composing the asteroids is assumed to be that of ice (2.05 kJ/kg·˚C), by how much does the temperature of the asteroids rise as a result of the collision in each case?
Before the collision, asteroid A (mass 1,000 kg) moved at 100 m/s, and asteroid B (mass 2,000 kg) moved at 80 m/s. (asteroid b is going i an opposite direction.)
After the collision I have
(1,000 kg)(100m/s) + (2,000 kg)(-80m/s)= -60,000/3,000 =20m/s
We haven't been taught temperature after collision so this is where i am stuck
How much KE was lost? Where has that energy gone?
There is no KE lost right? Since they collided and there is no external forces.
In an inelastic collision you should expect work energy to be lost.
You can calculate the KE before and after.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
