Temperature Variation Coefficient
The discussion focuses on determining the unit of the temperature variation coefficient, Ψ, in a system involving water and room temperature. The equation presented indicates that Ψ relates the change in temperature over time to the difference between the system's temperature and the room temperature. There is confusion regarding whether the unit should be degrees per second, as this is typically associated with angular velocity. It is clarified that temperature degrees and angle degrees are distinct units, which adds complexity to the interpretation. Ultimately, the conversation emphasizes the need for clarity in distinguishing between these units in the context of temperature variation.
Pochon
What is the unit of the system-universe temperature variation coefficient?
The system is a container holding a mass of water. T
The universe I guess is the room temperature. Troom
t is time in seconds.
\Psi is the temperature variation coefficient.
\DeltaT / \Deltat = \Psi(T - Troom)
\Psit = ln ((To - Troom) / (T - Troom))
Since it is temperature over time I thought that it would be degrees per second? But that is angular velocity so I'm sure that's not it.
Degrees that measure temperatures are different than degrees that measure angles. You may consider them to be entirely different units, even though it's the same word.
