Tensile Testing (Determining Young's Modulus)
Calculating Young's modulus from tensile testing may not be sensible if the material exhibits non-linear behavior or significant slipping during the test. The stress-strain curve must show a linear region to accurately determine Young's modulus, which is derived from the gradient of that linear section. If slipping occurs, it can lead to inaccuracies in the measurements, making the calculation unreliable. Therefore, proper conditions must be ensured during testing to obtain valid results. Accurate determination of Young's modulus is crucial for understanding material properties in engineering applications.
stpmmaths
Question:
Why is it not sensible to calculate the Young's modulus of the material (steel) when the experiments was conducted?
But I thought it should be possible to calculate the Young's modulus after plotting the stress/strain curve. Young's modulus can be found by finding the gradient of the straight line on the curve. But what with the question? :confused:
Is it related to the slipping which occurs during the test?
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
