What Determines Maximum Tension in a Cord Between Two Blocks on Inclined Planes?
In summary: It sounds like you are walking through a solution in your textbook. Is that right? Or is it just that your textbook provides a diagram with labels T1 and T2 in...In summary, the text book provides two different symbols for the tension in the cord at the apex - T1 and T2. If the cord is without friction, the tensions should be the same. However, if there is friction, the tension in the cord at the apex is greater than the tension in the cord half way between the left block and the apex.
mala06
Two blocks of weight 50N and 200N are connected by a cord rest on two inclined planes .determine the maximum tension in the cord when limiting friction condition develop in both blocks
R1=Reaction of weight 50N
R2=reaction of weight 200 N[/B]
for block of mass 50 N moving upward
µ1R1+wsin45-T1=0
for block of mass 200N assuming moving downward
T2+ µ2R2-W2sin30=0[/B]
:Its just that I am not able to understand why there is different tensions in the cord .Doesnt the tension should be equal if the cord is weightless?[/B]
What happens if there is no friction?
(By limiting friction" do you mean that the blocks are stationary or moving at a constant speed?)
by limiting friction i mean the bodies have just started to move overcoming friction .if there is no friction and if we consider tension same the the bodies will move in the direction of of 200N
They have just overcome the static friction - so they are in motion, and the coefficients are for kinetic friction?
Or they are just about to overcome static friction - and the coefficients are of static friction?
They have just overcome motion hence they are coefficient of static friction
OK - what would be the tension if there were some acceleration?
Does that tension depend on the acceleration?
i am just confused in this part i think the tension will remain same in this case.Yes i think it depends since f=m*a and tension is also one kind of forcwe
Yes, the tensions must be the same if the cord is massless and there's no friction at the pulley. What makes you think they're different?
That's not what limiting friction usually means. I would take it to be at maximum static friction.
That's inconsistent. If they have overcome friction then it's kinetic; if they haven't overcome it's static.
Yes it takes maximum static friction its just that in my textbook there are two different tension so i got confused and
The tensions are actually different, or merely it is using different variables to represent them? If the second, maybe there's an equation later that says they are equal.
They are represented by different variables in the textbook. but now i think since we have to find maximum tension in this question they are represented differently.But i am not so sure
Well, as I wrote, unless there is friction on the rope at the apex the tensions will surely be equal.
Then i think its a mistake of textbook since it hasnt said any tension in apex
Why would it? The text has not mentioned lots of things - that does not mean that it is wrong.
i.e. the text has not said anything about the tension half way between the left block and the apex ... but we can tell some things about that tension by thinking about the physics involved. Just cause it is not written down don't mean its not true.
If you consider the point on the rope exactly at the apex, you can see there must be some tension pointing each direction away from the apex. Since the rope is not accelerating, you can deduce that the magnitude of the tensions must be equal.
Your book has not said that the tensions T1 and T2 are not equal.
Different variable names may still have the same physical value.
Try redoing the calculation assuming that T1=T2 - be careful about the directions of your vectors.
Notes:
##\sin(45)=\cos(45)=1/\sqrt{2}##, ##\sin(30)=1/2##, ##\cos(30)=\sqrt{3}/2##.
I said friction at apex, not tension. And as Simon and I are both trying to explain to you, it is not wrong to use different symbols for entities that could in general be different but in the present case turn out to be the same.
It sounds like you are walking through a solution in your textbook. Is that right? Or is it just that your textbook provides a diagram with labels T1 and T2 in it?
Sorry i was trying to write friction at the apex.I am seeing solution in textbook and it clearly has two tension value
I'd like to see the exact wording of the question.
If you put a nail through the rope at the apex, fixing the rope at that point, it is easy to see why there would be a different tension on each side of the nail.
Ok, I think I understand what is going on here.
The T1 calculated is an upper limit on the tension for static equilibrium. If the tension exceeds this then block 1 will slide up. The T2 calculated is a lower limit on the tension for static equilibrium. If the tension is less than this then block 2 will slide down.
If the calculated upper limit were greater than the calculated lower limit then it would be stable. The actual tension would be anywhere in that range. (It can happen that it simply is not possible to determine the actual tension.). As it is, the lower limit comes out higher than the upper limit, so it is not stable.
But if I'm right, the final line in the textbook makes me feel the author has not understood the problem.
thanks for explaining.But i still have one confusion.How does the tension have upper and lower limits doesn't it should be equally distribured in the chord?
I have written the exact question and there is no wording about fixing the rope
There is only one actual tension throughout the cord. The calculation is finding an upper and lower bound for its value, on the assumption that there is static equilibrium.
If the upper bound is the greater then there is static equilibrium and the actual tension is somewhere in the range (but there is no way to find out where in the range).
If the lower bound is the greater then we have a contradiction, so the assumption of static equilibrium must be false.
In my view, the approach taken in the textbook is confusing, and even seems to have arrived at the wrong conclusion.
I would take the tension to be T both sides, then write down the constraints for static equilibrium each side.
##T<=m_1g\sin(\theta_1)+m_1g\cos(\theta_1)\mu_s##
##T>=m_2g\sin(\theta_2)-m_2g\cos(\theta_2)\mu_s##
Whence
##\mu_s(m_1\cos(\theta_1)+m_2\cos(\theta_2))>=m_2\sin(\theta_2)-m_1\sin(\theta_1)##
If that condition is satisfied, there is a T that produces static equilibrium (but we might not be able to say exactly what it is).
If the condition is not satisfied (as here) then it will slide. If we wish to find the tension in the cable we must now introduce an unknown acceleration and use the kinetic friction coefficient.
Your image of the textbook "solution" certainly helped. Can you similarly supply an image of the problem statement from the textbook?
Lacking that at the moment ...
This is my take on this problem in light of the supplied "book" solution.
Both tension, T1 and T2 are arrived at assuming that the fiction forces are to the left, thus opposing motion to the right.
The value of T1 that's calculated is the maximum value of tension, T, that will produce static equilibrium. (If we consider this to be a kinetic situation, then T1 is the minimum value of tension, T, that will enable sustained motion to the right.)
T2 is a bigger puzzle.
The value of T2 that's calculated is the minimum value of tension, T, that will produce static equilibrium. Any smaller value for T2 will give motion to the right. If T is greater than this (up to a point), then the static friction will simply be less than μ2R2, R being the normal force. (T2 can be as large as 120.78 N for static equilibrium.)
Considering the values of T1 and T2, there is no possibility of this system being in static equilibrium.
which txt book bro
which txt book
txt book name
mohan1234 said:
which txt book
txt book name
Hello @mohan1234 .
:welcome:
This tread is over 6 years old.
The person posting the thread has not visited Physics Forums since 2017.
I doubt that you will get an answer to your question.
What is tension between two blocks?
Tension between two blocks is the force that is exerted on each block by the other block when they are connected by a rope or string. It is a result of the pulling force applied by each block in opposite directions.
How is tension between two blocks calculated?
Tension between two blocks can be calculated using Newton's Second Law of Motion, which states that the net force acting on an object is equal to the product of its mass and acceleration (F=ma). In the case of two blocks connected by a rope, the tension can be calculated by multiplying the mass of one block by its acceleration.
What factors affect the tension between two blocks?
The tension between two blocks is affected by several factors, including the mass of each block, the acceleration of each block, and the angle at which the rope is pulled. The tension will increase if the mass or acceleration of either block increases, or if the angle of the rope decreases.
What happens to the tension between two blocks if one block is heavier than the other?
If one block is heavier than the other, the tension between the two blocks will increase. This is because the heavier block will exert a greater force on the rope, causing an increase in tension.
Can the tension between two blocks ever be zero?
Yes, the tension between two blocks can be zero if there is no external force acting on the blocks or if the blocks are stationary. In this case, the two blocks are not pulling on each other and there is no tension in the rope connecting them.
