Tension in a Rope: Calculate Force for 20kg
  • Thread starter Thread starter some_guy
    Rope Tension
To calculate the tension in a rope for a 20kg box, consider three scenarios: when stationary, moving upwards at a constant speed of 6m/s, and moving upwards with an acceleration of 6m/s. The tension is the upward force acting on the box, countering its weight, which is 196N (20kg x 9.8m/s²). For stationary conditions, tension equals the weight; for constant speed, tension remains the same; and for acceleration, tension increases to account for the additional force required. A free body diagram is essential to visualize the forces acting on the box, ensuring clarity in calculations. Understanding that tension always acts upward while weight acts downward is crucial for solving these problems.
some_guy
First post, so be nice :P
A box with mas of 20kg is hanging from a rope on a building site. Calculate tension when:
a) Stationary
b)Moving upwards at consteant speed of 6m/s
c)Moving upwards with accelleration of 6m/s
f=ma
I don't know as i have never seen 'tension' used in a question before but i am guessing that for a) you take acceleration as -9.8m/s2 (gravity) and work out force. for b) same as a and c) is -9.8+6 and then into equation.
I am quite new to this (as you can tell) and got confused with tension. I am currently taking tension as the quivilent of force.Am i right? (P.S: I could use 9.8 as acceleration if i wanted positive answer).
Yes. The tension is the force pulling up on the box. The other force acting is the weight of the box, down. You must draw a free body diagram that identifies both forces, and solve for the unknown tension force using Newton's first law (Fnet = 0) or
2nd law (Fnet = ma), as applicable. Please watch your directions and use of plus and minus signs. Don't take any shortcuts.
so tension is the upward force not downward?
Yes, it acts upward on the box. Tension forces always pull away from the objects they act on. When you isolate the box in a free body diagram, the weight acts down on the box, toward the center of the earth, and the tension force pulls up on the box, toward the top. I understand your confusion; if you look at the hook at the top to which the rope is attached, the tension force, pulling away from the hook, acts down (per Newton 3). It is important to isolate the object in question with a good free body diagram.
right thanks for the help! It has cleared up everything perfectly!
