How Do You Calculate Tension in a Descending Elevator?
  • Thread starter Thread starter yosette_ledezma
    Elevator Tension
To calculate the tension in a descending elevator, the formula T + mg = ma is used, where T is tension, m is mass, g is gravitational acceleration, and a is the elevator's acceleration. Given a mass of 2003 kg and a downward acceleration of 1.4 m/s², the tension is calculated as T = 2003(-9.8) + 2003(1.4). The correct calculation shows that tension decreases when the elevator accelerates downwards, and if it were in free fall, the tension would be zero. The confusion arises from not accounting for the direction of forces properly. Understanding these principles clarifies how tension behaves in relation to acceleration.
yosette_ledezma
So I am really stuck on this physics problem, its an elevator that is accelerating downward at a constant acceleration and I need to find the Tension on the rope
T=?
m=2003kg
a=1.4m/s^2
g=-9.8
T+2003(-9.8)=2003(1.4)
T=22433.6
What am i doing wrong?
If it is accelerating downwards, should the tension in the rope get more or less?
Hint - what would be the tension in the rope be if the elevator was free falling?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
