Tension in Room: Find Force of Friction
  • Thread starter Thread starter youenjoymyself
    Tension
The problem involves a cart with a mass of 20kg being pulled at a constant speed on a horizontal surface by a rope inclined at 30 degrees. The coefficient of kinetic friction is given as 0.45, and the goal is to determine the tension in the rope.
  • Exploratory, Assumption checking
  • Participants suggest drawing the components of the forces acting on the cart. There is a request for a step-by-step breakdown of the solution process, and one participant encourages sharing visual attempts to aid understanding.
The discussion is ongoing, with participants exploring different ways to visualize and break down the problem. Guidance has been offered regarding the drawing of force components, but no consensus or resolution has been reached yet.
There is an emphasis on the need for visual aids and detailed breakdowns, indicating that participants may be grappling with the complexity of the problem setup and the relationships between the forces involved.
youenjoymyself
A cart loaded with books has a total mass of 20kg and is pulled at a constant speed by a rope inclined at 30 degrees above the horizontal. The cart moves a distance of 10m on a horizontal surface. The coefficient of kinetic friction between the cart and the surface is 0.45. Find the tension in the rope.
F=ma
[h2 said:
The Attempt at a Solution[/h2]
Try drawing all the components of the forces.
I have I need a step by step breakdown.
Post a picture of your attempt. Even an MS Paint jpeg would do.
  • · Replies 38 ·
  • · Replies 18 ·
