Calculate Tension in 5m String Attached to 4kg Bob
To calculate the tension in a 5 m string attached to a 4 kg bob moving in horizontal circles with a 0.6 m radius, the angle α is determined to be approximately 6.9 degrees. The correct equation for tension is T cos α = m*g, leading to T = m*g/cos α. After correcting calculations for cos 6.9 degrees, which is approximately 0.992757341, the tension is recalculated to be around 39.5 N. The initial calculation of tension at 326.6 N was incorrect due to misapplication of trigonometric functions. The final tension value confirms the need for precise angle calculations in physics problems.
John78
Calculate the tension in a 5 m string attached to a 4 kg bob that is moving in horizontal circles of 0.6 m radius.
α= tan-1 0.6/5
= 7 degree
T cos α = m*g
T= m*g/cosα
T=4*9.8/0.12
T=326.6 N
I just want to check whether my working is correct or not.
Your equations are almost correct, however, if the angle α is 7 degrees, then cos α = cos 7 = ? But your calc for that angle is not right. It is not the tan function per your attempt...
so am I right in my calculations
α= sin 0.6/5
= 7 degree = 0.121869343
T cos α = m*g
T= m*g/cosα
T=4*9.8/0.121869343
T=321.65N
α= sin^-1 0.6/5 = sin^-1 0.12
α = 6.9 degrees[/color]
T cos α = m*g
T= m*g/cosα
yes
T=4*9.8/0.121869343
No, the cosine of 6.9 degrees is not 0.121869343
cos 6.9 = 0.992757341
Am I right?
Am I right?
yes, so T = ?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
