Tension in vertical circular motion
The discussion revolves around the tension in a vertical circular motion scenario involving an object of mass 3.25 kg attached to a 0.8 m long chain, spun at 20 rpm. Participants explore the calculations for tension at various points in the circular path, including the top, at a 43° angle, and at the bottom.
  • Mixed
  • Participants discuss the assumption of constant velocity and question whether the object can maintain this speed throughout the circular path. There are considerations about the implications of conservation of energy on the velocity at different points. Some participants also explore the relationship between centripetal force and tension.
The conversation includes attempts to calculate tension values, with some participants expressing uncertainty about the signs of their results and the physical feasibility of the scenario. There is a recognition of the complexity involved in maintaining constant speed with a chain, and various interpretations of the problem's wording are being examined.
Participants note the potential for external torque to influence the motion and question the assumptions underlying the problem setup, including the nature of the forces acting on the object during its motion.
joel amos
If you are spinning an object of mass 3.25 kg on a 0.8 m long chain at 20 rpm (vertical cirular motion), a) what is the tension at the top b) 43° from the top and c) at the bottom?
String tension: T = Fc - mg cosθ
Tension at top: T = (mv^2/r) - mg
Tension at bottom: T = mv^2/r + mg
Average velocity: v = r × RPM × 0.10472
I've found the average velocity given the rpm, which is 1.58 m/s. I have all of the tension formulas that I need. The only problem is that I don't know how to find velocity for a given point on the circular path.
Or...should I just assume that the object is being spun at a constant velocity?
The rpm is given as a constant. The radius is constant, so is the speed. ehild
It does not have to be a constant velocity does it?
I think that has to go by context - it could well be that you are supposed to do all this with the constant average speed.
[ehild will probably tell me off for this ...]
... but don't you have conservation of energy to give you some limits on what v can be at the top - given the rpm? i.e. there is a minimum speed it has to be going to stay on a circular path ... but if it goes too fast at the top (slowest part of the trajectory?) then it will complete a circle in less than the 3 seconds needed for 20rpm.
(A constant rpm may imply a constant angular velocity or it could imply that you have 20 cycles in each minute - i.e. it is an average.
I think this is a judgement call.)
aside:
"##v = r \times RPM \times 0.10472##" is better written as :
##v=r\omega_{[rpm]}\pi/30## ... says you know what the numbers mean.
(It sounds pedantic but this sort of thing is worth marks.)
Yeah, I guess I'll just assume that velocity is constant.
Now for part b) T = Fc - (3.25 kg)(9.8m/s/s) cos(43)
How do I find centripetal force in this situation?
How do you get the centripetal force in general?
ehild
It would be a nice problem to find the speed along the circle assuming conservation of energy, so the object makes a certain revolutions per minute.
The problem does not say that the object spins by itself. There can be some external torque to make it spin with uniform angular velocity.
ehild
ehild
Exactly
ehild
Yeah, it was a stupid question: Fc = (mv^2)/r
Exactly :smile:
ehild
I got tension at top to be -20.384 N, at 43° to be -11.83 N, and at bottom to be 43.32 N. Does this look good?
You don't really need the -signs.
As for the answers, generally speaking, tension is always greater at the bottom of a rotation (I think) due to gravitational potential energy being converted into kinetic energy - judging from this, I would say your answers are right.
But is it possible to spin that object with a chain at so low rpm? Will it not fall on your head?
ehild
ehild
It does turn it into a "how do you handle the un-spoken assumptions?" problem, yes.
Well, that means push instead of pull except the bottom point. Can a chain push? Or will that object fall on your head?
But if the object is fixed to a rod, it looks correct.
ehild
Pretty tough to spin an object at constant speed in a vertical circle using a chain. I mean this is not a ferris wheel where a constant speed can be maintained with an external torque. I believe with a chain you have to move your hand in some sort of elliptical path to maintain constant speed throughout. Poorly worded question if you ask me.
I agree.
ehild
