Solving Tension of Cable Supporting 56kg Beam - kN
  • Thread starter Thread starter o0ojeneeo0o
    Cable Tension
The discussion revolves around calculating the tension in a cable supporting a 56 kg beam with two attached weights. The user has provided the masses and forces acting on the system but is unsure how to proceed with the calculations. Key equations for equilibrium, including the sum of vertical forces and torques, are mentioned, but the user is advised to focus on torque calculations about the pivot point for accuracy. The suggestion emphasizes the importance of identifying forces acting at the pivot to solve for tension correctly. Overall, the conversation highlights the need for a systematic approach to solving static equilibrium problems in physics.
o0ojeneeo0o
Two weights attached to a uniform beam of mass 56 kg are supported in a horizontal position by a pin and cable as shown in the figure.The acceleration of gravity is 9.8 m/s2 .
What is the tension in the cable which supports the beam? Answer in units of kN.
here's what I have thus far... I'm sorry, I know it's not much!
Known:
Mbeam= 56k
Mass 1 = M1 = 22kg
Mass 2 = M2 = 59kg
Force of M1 = F1 = M1g = 215.6N
Force of M2= F2 = M2g = 578.2N
ΣFy = 0
ΣFx = 0
ΣFτ = 0
If ΣFy = 0, then:
0 = Fcy – mg – F1 – F2
If ΣFτ = 0, then:
0 = -mg(4.2m) – F1g(2.6m)
I'd really love it if someone could solve this for me, but it would be even better if someone could walk me through how to get the answer because I honestly have no clue!
Thank you in advance!
It is a mistake to use ΣFy = 0 because you don't know what force acts at the pivot point on the wall. Instead, use the sum of the torques = 0. Take the torques about that pivot point marked with a big black dot.
