Tension of a rope on a cone, fallacious solution
  • Thread starter Thread starter ZetaOfThree
    Cone Rope Tension
The problem involves determining the tension in a rope of mass ##m## that is placed over a smooth round cone with a half angle ##\theta##. The original poster attempts to explore different methods of solving the problem, including balancing forces on small elements of the rope and considering larger sections of the rope.
  • Participants discuss the necessity of considering small elements of the rope versus larger sections, questioning the implications of tension being non-constant along the rope's length. There is also mention of using energy methods as an alternative approach.
The discussion is active, with participants providing insights into the nature of tension and normal forces acting on the rope. Some participants suggest that the original poster's alternate approach may not account for the varying direction of forces along the rope, while others offer different perspectives on solving the problem.
Participants note that the rope forms a full circle and that there are no ends to consider, which influences the analysis of forces. The original poster acknowledges a misunderstanding regarding the direction of forces acting on the rope.
ZetaOfThree
A rope of mass ##m## forming a circle is placed over a smooth round cone with half angle ##\theta##. Find the tension in the rope.
##\sum{F}=0##
I know how to solve the problem, but I have another way that I think should work but it doesn't. I don't know why.
The way that this problem is done is to consider the tension on a small element spanning an angle ##\alpha## of the rope as shown in the following image:
. From there, we balance the forces on that small element as shown in the following image:
. We find that $$T={m \over 2 \pi}g \cot{\theta}$$
My question is why do we have to consider a small element of the rope? Why can't we consider half of the rope (that is, an element of the rope spanning ##\alpha = \pi##)? Therefore, the tension acts on the rope as in the following figure:
, leading to a free-body diagram as in the following image:
This leads to the result $$T={m \over 4}g \cot{\theta}$$ What's going wrong?
There is no tension at the end of the rope, and tension is not constant over the length.
In your alternate approach, I'll give you "2T" or "mg/2," but not both; "pi" ain't obvious to me yet.
How is the normal force acting on different parts of your string?
The rope is a full circle and has no end ;)
Oh, I misread how the rope is placed.
In that case: the force is not acting in the same direction everywhere.
Just as a comment regarding alternative ways of approaching the problem: I would actually prefer to solve this one by using energy methods. The answer drops out quite naturally without having to consider individual parts of the rope.
I know what's wrong with my alternative solution. The component of the normal force that opposes ##2T## is a sum of small normal forces acting in the direction opposite to ##2T##, which act on each element of the rope perpendicular to the surface of the cone. The force that opposes ##2T## can be found using integration and you get the correct answer.
Yeah, virtual work does give the result in like two lines. I was trying to find as many solutions to this problem as a could. I should have been more careful with my alternative solution above. I assumed the the force from the cone would be in a direction at angle ##\alpha## from the horizontal. For half the rope, this is not the case.
Thanks for the responses everyone!
  • · Replies 38 ·
  • · Replies 18 ·
  • · Replies 22 ·
