Tension problem involving Centriptal force
  • Thread starter Thread starter Lucky14
    Force Tension
The discussion revolves around calculating the tension in two strings supporting a mass rotating around a stick. Key points include recognizing that the net force in the vertical direction is zero, which implies that the tensions must balance the weight of the mass and the centripetal force. Participants emphasize the importance of labeling forces and applying Newton's second law to derive equations for tension in both strings. There is a common misconception that the upper string supports all the weight, but the problem requires understanding the distribution of forces. The solution involves analyzing the components of tension in both the x and y directions to find the correct values for T_1 and T_2.
Lucky14
I am having a tough time solving this problem where a mass, connected to two strings with equal distance fixed to a stick, rotates around the stick at a given speed and i need to solve for tension in both the upper and lower string.
Looks like this
http://www.webassign.net/pse/p6-11.gif
Thank You for your time
What i really need to know is how the weight vector of the mass is reflected in the tension.
I guess the most subtle but improtant hint would note that there is no acceleration in the y direction... from there you can list your forces and solve the system of equations.
i know the net force on the y-axis is equal to zero and the tension must somehow balance both the weight of the object and the centriptal force of the object. My real trouble is that i think that the higher string is supporting all of the weight of the object but i keep getting the wrong answer. Does anyone know how the force of the objects weight is reflected in the tension forces.
It seems like you want to write the answer directly, solving it in your head. Don't! Instead, label the forces, apply Newton's 2nd law, and solve for the tension in each string.
Call the tension in the strings T_1 (top) and T_2 (bottom). What are the components of the tensions in the x and y directions? You realize that the net force in the y-direction must be zero: Good! What must the net force in the x-direction equal?
