Tensor calculus, dummy indices
Telemachus
Hi there. When I have dummy indices in a tensor equation with separate terms, I wanted to know if I can rename the dummies in the separate terms.
I have, in particular:
\displaystyle w_k=-\frac{1}{4}\epsilon_{kpq}\left [ \frac{\partial u_p}{\partial x_q}-\frac{\partial u_q}{\partial x_p} \right ]=-\frac{1}{4}\epsilon_{kpq}\frac{\partial u_p}{\partial x_q}+\frac{1}{4}\epsilon_{kpq}\frac{\partial u_q}{\partial x_p}=\frac{1}{4}\epsilon_{kqp}\frac{\partial u_p}{\partial x_q}+\frac{1}{4}\epsilon_{kpq}\frac{\partial u_q}{\partial x_p}
I've used that \epsilon_{kpq}=-\epsilon_{kqp}
So, if I can change the dummy indices for the separate terms I can use that:
to get:
w_k= \frac{1}{2} \epsilon_{kqp} \frac{\partial u_p}{\partial x_q}
which is the result I'm looking for, but I wasn't sure if the last step is right.
mhm, I think that it suffices to just take separate sums for the different terms to see that yes, I just can change the dummies.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
