Termochem problem. Work required to heat water
  • Thread starter Thread starter Dars
    Heat Water Work
To solve the problem of heating 1 L of water by 10 ºC using a mechanical egg beater powered by a descending mass, one must calculate the work required based on energy conservation principles. The key equation is q = w, where q represents the heat energy needed to raise the water's temperature. The specific heat capacity of water and the desired temperature change can be used to find the total heat energy required. The work done by the descending mass can be calculated using gravitational potential energy formulas. Understanding these relationships is crucial to determining how far the mass must descend to provide sufficient work for heating the water.
Dars
"You want to heat 1 L of water by 10 ºC so you heat it with a mechanical egg beater that is powered by a 1kg mass on a rope over a pulley. How far does the mass have to descend to supply enough work for heating the water?
delta T = 10degC
delta C = delta Q / delta T
Work in gravity is: integ x_f / x_i (mg)dx
I don't understand how to get the work. If i knew delta U then I could use U = q+w. So i am stuck as to where to start. Please help me get started..thanks
It is just an energy conservation problem, q=w, nothing more fancy.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
