Textbook 'The Physics of Waves': Lifetime of SHM Oscillators
The discussion centers on the concept of "lifetime" in oscillators, particularly focusing on underdamped, overdamped, and critically damped systems. It clarifies that while the lifetime of underdamped oscillators is defined as the time for amplitude to reduce by half, similar definitions can apply to overdamped and critically damped oscillators, although they typically do not exhibit oscillations. The term "lifetime" can be vague, with various definitions such as the time for amplitude reduction by factors of 1/e or 1/sqrt(e). The equations for overdamped and critically damped oscillators differ from underdamped ones, but the underlying principle of amplitude decay remains consistent across all types. Understanding these distinctions is crucial for accurately describing the behavior of different oscillator types.
brettng
The lifetime of the state in free oscillation is of order ##\frac 1 { \Gamma }##.
$$\tau=\frac { \ln(4) } { \Gamma }$$
Reference textbook “The Physics of Waves” in MIT website:
https://ocw.mit.edu/courses/8-03sc-...es-fall-2016/resources/mit8_03scf16_textbook/
Chapter 2 - Section 2.3.2 [Page 47] (see attached file)
Question: In the content, it states that the lifetime of the state in free oscillation is of order ##\frac 1 { \Gamma }##. To my understanding, it means particularly the half-life of underdamped oscillators with position ##x\left( t \right)##:
$$x\left( t \right)=Ae^{ -\frac {\Gamma t} {2} }\cos(\omega t-\theta)$$
However, could I consider the "half-life" of overdamped oscillators and critically damped oscillators?
If so, would it still be of order ##\frac 1 { \Gamma }##?
Do you understand what is meant here by "lifetime"? Also, what do the equations for ##x(t)## look like over damped and critically damped oscillators?
I understand that lifetime means that the oscillation amplitude reduces by a factor of 2.
So, why can’t we still consider the “lifetime” of overdamped and critically damped oscillators by using the same definition?
In practice, people only refer to "oscillations" wrt underdamped systems. Otherwise we tend to use "rise time"; usually defined as 10-90%, tr = 2.2τ. But it is the equation that holds the real answers, the rest is just jargon.
Likes brettng and DrClaude
That would be the half-life. Lifetime itself is actually more vague. For instance, in this case one could take ##\tau = 1/\Gamma##, which would be the time for the oscillation amplitude to be reduced by a factor ##1/\sqrt{e}##, or ##\tau = 2/\Gamma##, for a reduction of the amplitude by ##1/e##. They are all of order ##1/\Gamma##, as the text states, and as @DaveE stated, they all relate to a decrease of the amplitude of oscillations, and different terminology is used for critically and over-damped oscillators, which do not actually oscillate.
Likes brettng and DaveE
Thank you so much for your help!!!!!!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
