The antiderivative ofx*exp(1-x)
  • Thread starter Thread starter Broken_Mirage
    Antiderivative
Broken_Mirage
pleasezz the antiderivative ofx*exp(1-x)
hi all,,,,,,
tomorrow 11/1/2007 is the last day
please
You left it a bit late didn't you? Anyway, please provide your thoughts on a solution to the problem (for example, do you know any methods of integrating products?) Better still, in future, use the homework posting template with which you were provided!
Well since you don't really have much time, Ill just get through to you the essentials, But can't give you the answer.
\int u dv= uv-\int v du
Let u=x, dv= e^(1-x) dx. Differentiate u with respect to x, and take the dx to the other side to get du. Integrate dv to get v. Once you have those values, sub them into that equation and your done. Good Luck
EDIT: O btw this is obviously calculus, put this is the calculus section next time.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
