Exploring the Effects of Dielectric Insertion on Capacitor Behavior
  • Thread starter Korisnik
  • Tags
    Capacitor
In summary: is to push the dielectric in more... which would decrease the charge on the plates because the dielectric would be pulling electrons off of the plates.
Korisnik
62
The capacitor and dielectric
A small dielectric plate is pushed between parallel plates of an (1) isolated capacitor to the half of its length. If the dielectric is let to move freely, what's going to happen to it? (2) What would happen with the dielectric if the capacitor was connected to the voltage source?
[itex]E=\frac{1}{2} CU^2=\frac{Q^2}{2C}~~(1)[/itex]
where [itex]U[/itex] is voltage, [itex]C[/itex] capacity, [itex]Q[/itex] charge on plates, [itex]E[/itex] energy of the electric field of the capacitor.
[itex]C=ε_0ε_r\frac{S}{d}~~(2)[/itex]
where [itex]ε[/itex] is permitivity, [itex]S[/itex] area of one plate, [itex]d[/itex] distance between the plates, [itex]C[/itex] capacity of the capacitor.
When the dielectric enters the capacitor, the capacity, by the (2) equation increases, therefore by the (1) equation the energy of the part of the capacitor where the dielectric is - decreases, because [itex]Q[/itex] is constant (isolated capacitor), and [itex]C[/itex] is reverse-proportional to the energy [itex]E[/itex]. Because the energy of the first part (where the dielectric is) decreased and is lower than on the other part of the capacitor, the dielectric tends to go to the lower energy and is therefore pushed out of the capacitor.
For the second question the same rules are applied but this time the reverse thing happens because the energy increases ... the dielectric get's pushed in.
Is any of this correct?
'Fraid not.
For the isolated capacitor, you correctly state that the stored energy after dielectric insertion is lower. So what happened to the "lost" energy?
For the capacitor with constant potential V, the energy is 1/2 C V^2 so what happened to C after insertion (see your equation 2), what is the new stored energy and what had to be done to get it?
Likes 1 person
rude man said:
'Fraid not.
Lost energy was spent in the voltage decrease, so maybe... the distance between the plates [STRIKE]increased[/STRIKE] decreased, but that's impossible because they probably cannot be [STRIKE]away[/STRIKE] closer. So the charges probably neutralized, or something... I don't know.
Where there's constant voltage, and capacity of the plates increased, the energy increased. That was done through bringing of the new charge from the voltage source...
EDIT: Or maybe I was on the wrong track; maybe THE SYSTEM wants to decrease ITS energy, therefore it pulls in the dielectric in the first case, and pushes out in the second?
Part (a): The total energy of the system remains unchanged. Conservation of energy. The energy stored in the field is reduced, so some other form of energy must be produced. Think about what form that new energy consists of. Hint: think of letting go of the dielectric when it's just beginning to enter the plate area. What happens? What's the situation when the dielectric is centered inbetween the plates?
Part (b): Your statement is correct, but you haven't described what happens as the dielectric is inserted.This is a more difficult problem since there are two sources of external energy: the force on the dielectric times the distance traveled, plus the energy supplied by the battery. You need to isolate the two since you're interested in the former energy source only.
I think that when I'm putting the dielectric into the condenser it pulls it in, because the molecules in the dielectric polarise, in both 1st and 2nd problem. It's definitely easier to push it in in the case where the voltage is constant as more charge comes to the plates (faster) but it gets harder after because it's polarised already. I've never held a condenser or have put in a dielectric... I don't know. Nowhere in my book is that process described, the question is as I've written it.
The only thing I can think of to decrease the voltage in the first problem is that an electron jumps over to the other plate. (Because if for example the energy of the first part of the plate is decreased, the energy on the other half is increased.)
You need to use Gaussian surfaces and get a quantitative feel for what's going on rather than engage in qualitative speculation.
Electrons are not jumping anywhere.
Contemplate the possibility that it takes positive force to insert the dielectric in one case and negative in the case of another.
1. What is a capacitor?
A capacitor is an electronic component that stores electrical energy in an electric field. It is made up of two conductive plates separated by an insulating material called a dielectric.
2. How does a capacitor work?
A capacitor works by storing charge on its plates. When a voltage is applied across the plates, electrons from one plate are attracted to the other, creating an electric field between them. This electric field stores energy, allowing the capacitor to function as a temporary energy storage device.
3. What is the role of the dielectric in a capacitor?
The dielectric in a capacitor serves as an insulating material between the two plates. It prevents direct contact between the plates, allowing the capacitor to store charge without the risk of a short circuit. It also affects the capacitance of the capacitor, as different dielectric materials have different levels of electrical permittivity.
4. How is the capacitance of a capacitor affected by the dielectric?
The capacitance of a capacitor is directly proportional to the dielectric constant of the material used as the dielectric. This means that a higher dielectric constant will result in a higher capacitance, while a lower dielectric constant will result in a lower capacitance.
5. Can a capacitor function without a dielectric?
No, a capacitor cannot function without a dielectric. The dielectric is a crucial component that allows the capacitor to store charge and function properly. Without a dielectric, there would be no separation between the plates and the capacitor would not be able to store energy.
