How Can You Solve Compton Effect Homework Questions on X-ray Scattering?
  • Thread starter Thread starter Propagandhi
    Compton effect
The discussion focuses on three homework questions related to the Compton effect and X-ray scattering. The first question involves calculating the energy of a recoiling electron after X-rays of 543 keV undergo Compton scattering with a shift of 3.83x10^-13 m. The second and third questions ask for the maximum fractional energy loss for gamma rays of 0.491 MeV and 0.778 MeV, respectively, when scattered from free electrons and protons. Participants suggest using the Compton shift equation and the energy-wavelength relationship for solving these problems. Concerns are raised about the validity of the first problem, noting that the scattering value appears incorrect as it should result in an increase in wavelength.
Propagandhi
I have 3 homework questions that I need help with:
Q1 X-rays having an energy of 543 keV undergo Compton scattering from a target. The resulting Compton shift is 3.83x1E-13 m. Find the energy of the recoiling electron. (units: keV)
Q2 Find the maximum fractional energy loss for a 0.491 MeV gamma ray that is Compton scattered from a free electron.
Q3 Find the maximum fractional energy loss for a 0.778 MeV gamma ray that is Compton scattered from a free proton.
As far as these questions go, the only thing I can think of doing is somehow manipulating the compton shift equation
delta λ =h/MeC (1-costheta)
or should I use the equation E=hc/λ?
Any help with these problems is very appreciated. Also, if I'm not in the correct forum, please direct me to the correct one.
Thanks.
In 1st problem you have given scatter value (3.83*10-13 m) which is less value compare to incident wavelength:)that i have calculated (3.6*10-12m). According to compton effect wavelength should increas after scattering hence problem is wrong:-)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
