McHeathen said:
Yes, but if this were done to electrons it would be an act of observing and would therefore collapse the waveform.
There is a certain amount of misunderstanding here that needs to be corrected.
Let's say you have a wavefunction \Psi that describes a particular system. When you make a measurement (and this should be emphasized very clearly), it corresponds to operating some operator (call it operator A) we named as an observable to this wavefunction. Now, assuming that this is an eigen operator of that wavefunction, you can get one of the many possible values (called the eigenvalue) as the outcome of this measurement. So when you do this and get a value, we call this as "collapsing" the wavefunction because it now has a particular value for this observable.
But you need to remember that this observable can possibly be one of the
many observables that can be measured. You have possibly only collapsed the superposition of this observable. If there is another observable, called it B, and it does NOT commute with observable A, the act of measuring A doesn't change the superposition state of observable B!
So what you are "collapsing" isn't the wavefunction, but rather the representation for that particular observable. That's it. This means that asking if something collapses if it is "observed" is rather vague.
WHAT exactly is being "observed"? It's position? What was the wavefunction before? Was there a superposition in position? Is this what is being "collapsed"?
There is also another issue that should be mentioned. When we deal with "free" electrons in vacuum, especially for a CRT, you will note that practically ALL of the descriptions for such a system rely on purely
classical physics, not QM description. In fact, go to a particle accelerator and look at the codes they use to study the beam dynamics of the particles that are zooming around in such accelerators. You'll see that inevitably, they are using classical particle description to describe such a system, not quantum mechanical. Why? Compare to conduction electrons in metals, these free particle are so far away from one another, each of their "wave" nature does not overlap, and they are essentially classical particles. We track them the way we normally would any other classical particles. That's why we can design the CRT on your old TV without ever using QM, and the electrons can be predictably controlled without any "weird" quantum properties popping up.
So the question of collapsing such "wavefunction" on something like the position of such particles is a bit puzzling in light of what we already know and can do. Now, if you pass such a beam through a Stern-Gerlach type setup whereby you attempt to measure the spin of the electrons, that's a different matter. In this case, the observable will be the spin states, or more accurately, the spin projection operator. That observable is certainly in a superposition and will only be determined once it is measured.
Zz.
