The difference between the Heat and Diffusion equation ?
thepioneerm
the difference between the Heat and Diffusion equation ?!
Please:
What is the difference between the Heat and Diffusion equation ?!
thank you.
There is no difference. They are just different names, referring to different applications, for the same type of equation: more formally, a parabolic PDE.
thank you very much
but I mean the difference case of the coefficient k of the second derivative of u with respect to x
If k > 0 ....
If k < 0 ....
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
